Under dash clunk
https://www.ford-trucks.com/forums/1...end-clunk.html
There are 2 different threads started on this same noise...Here is one, the other has 3 pages of comments.
I have the same issue, hopefully one us can get a fix.
Thanks for the info airhawk...I don't feel I have the same issue. Mine is happening on city streets at lower speeds and does not feel or sound like the front end.
I have crawled up under the dash and cant find any obvious issues but will check again in the AM. What I remember of the post that I talked about earlier showed a pic of the steering shaft through the firewall.
I have a 2017 F-350 and have the same clunk. It is driving me crazy... I have been trying for a couple of months to feel where this clunk is coming from. It happens when there are small bumps in the road. It almost sounds like a cable of some sort is rapping against the back of the radio.
Just soooo much plastic in truck. On a side note I had a horrible tick in my driver side b pillar drove me nuts. I solved by filling b-pillar with pillow stuffing. The seat belt mechanism is a horrific noise generator and generates a variety of noises. ticks, springing sounds, rattles. I also covered the mechanism with heavy foam/felt. I drove around with the plastic trim removed and it is just constant. Cant eliminate the mechanism but you can stop the pressure waves from propagating. As far as other noises after a couple hundred thousand miles hopefully the plastic will wear each other away, lol
Thanks for the info airhawk...I don't feel I have the same issue. Mine is happening on city streets at lower speeds and does not feel or sound like the front end. I have crawled up under the dash and cant find any obvious issues but will check again in the AM. What I remember of the post that I talked about earlier showed a pic of the steering shaft through the firewall.
EDIT TO UPDATE: Found my clunk was NOT from the steering shaft as reported HERE.
Is it starting to get cooler out where you live? I only hear my clunk at about 25 Celsius (77 Fahrenheit) and above. Now that our temperatures are well below that I
can not hear the clunk happening. I mentioned in the other thread that I thought the clunk was somewhere under the dash at first because it sounded like somebody
had left a socket under there somewhere and it was rolling around. As we put miles on the truck the sound progressively got more frequent while driving down the road
during warm weather. Can you fell your clunk at all in the steering wheel or around your feet or do you just hear it?
CFICARE suggested to try grabbing the intermediate steering shaft and jiggling it because we can hear a clunk doing this. When I do this on my truck it seems the clunk
is coming from the upper part of the shaft where the bushing is located. This is close to the firewall and it might be a possibility that it is what you might have.
Then again, you might have something different than what we think we have.
I had a clunking noise on my brand new 2018 F350. Dealer zip tied some stuff under the truck in the front and declared it fixed. It was clunking again before I left the lot. Sigh. But the reason I knew it was under the dash was I felt the clunking vibrate the gas pedal. So I crawled underneath and found a wire harness above the accelerator that had dropped out of place. It had one of those black plastic push in retainer clips. I believe that was hitting the gas pedal. I cannot locate where that retainer came from but I simply zip tied the loose harness to another harness making sure it was pulled away from the gas pedal. I was really nervous as this clunking was driving me crazy driving it home from the dealer after buying. I know how difficult it can be tracing noises. And I'm sure a dealer wouldn't want to put much effort into it. I'm thankful I found the problem.
Now it's as quiet as a Lincoln. Well...sort of.
Not sure this will help anyone but I thought I'd put it out there.
