In the process of installing a 4 barrel carb. I found a bell crank out of an old 6 cyl. to line ilinkage up on drivers side. Problem is I don't have enough pedal travel to work the carb fully. It's a manual/overdrive so there is the solenoid under the pedal (if that matters) I'm in a bit over my head, any help would be appreciated.
Thank you
Jason
Thank you Smitty
That looks interesting. Don't have any experience with that. I will have to take a closer look when I get home tonight.
If any one has any tips installing this kind of set up I would appreciate it.
Thank you again
Jason
In my 52F1 with a 54 Merc Yblock and a new small Holley I used a hanging pedal from a 90s GMC Astro van and a Lokar cable. Works great and has full travel.
Reason: Double
