Oil pick up tube help please
Old 08-15-2018, 11:58 AM
5.43v's Avatar
5.43v
5.43v is offline
OK I'm installing the melling hv pump and I've stripped out the holes. Has anyone come across this?
My plan is to drill out the left hole through and through and drop a bolt from the top down, will one bolt be sufficient? The other side I tapped out and I'm still going to try to insert it but if I can't I'm hoping just the one bolt will work if I put two o rings instead of one??
Old 08-15-2018, 08:19 PM
redfishtd's Avatar
redfishtd
redfishtd is offline
people have broke oil pump body when not seated correctly and tightened .
Haven't had this problem . That o ring seal very important so is cleaning out oil pu screen . A lot of guys don't want to believe how jammed up all those fibers are in screen , can't clean it with out removing it . I would make sure its a very good repair. This engine needs good oil flow and not be sucking air .can it be heli coiled or welded and re tapped.
Old 08-15-2018, 10:08 PM
5.43v's Avatar
5.43v
5.43v is offline
I might have a solution that helps others I drilled out the left hole through and through and dropped a bolt down I got the other one in thank God, I re tapped it tho. With the oil pick up tube screen I poured kerosene through it the let it sit then with the drain plug off so it kind of back flushed it. Better then nothing .
I know have a problem with the timing, a question of sorts so I'll start a new thread
Old 08-16-2018, 07:10 PM
redfishtd's Avatar
redfishtd
Believe me it is hard to get those fibers out of there , once the chain and reluctor wheel have ground them up . .The suction of oil pump jams them in tight Dropping oil pan is very necessary . Oh well . Glad you got her tapped out .
Old 09-01-2018, 04:38 PM
anaheim_drew's Avatar
anaheim_drew
anaheim_drew is offline
I had no trouble installing mine years ago
Old 09-01-2018, 05:22 PM
5.43v's Avatar
5.43v
5.43v is offline
Don't lie I know you don't own a 5. 4 3v engine
Old 09-01-2018, 05:33 PM
anaheim_drew
You as so clueless
Anyway. 2005 Ford F150 Supercharged 5.4 3v Supercrew Lariat
From a forum contest here in 2008
Old 09-01-2018, 05:55 PM
5.43v's Avatar
5.43v
5.43v is offline
Hahaha sure
Old 09-01-2018, 06:07 PM
anaheim_drew
Hahaha sure
post 292
https://www.ford-trucks.com/forums/7...maries-19.html
Old 09-01-2018, 08:53 PM
anaheim_drew
Originally Posted by anaheim_drew
more pics from this site
ithaca1230
09-12-2018 01:42 PM
Wishing Faery
06-07-2016 09:57 PM
cars2cool
11-11-2008 05:12 PM
crash12884
General Automotive Discussion
11-23-2006 12:07 PM
geezer95
04-14-2005 08:07 AM
Quick Reply: Oil pick up tube help please
