New to the forum
New to the forum
So I introduced myself in the "new guy" forum. I'm getting a 1961 F350 flare side. 6cyl recently built from the ground up. Can you guys take a look for glaring issues please? My goal will he to get it to as stock as possible but maybe upgrade the brakes and whatever else to make it safer. It was my grandfather's , who has past on, then my father started the rebuild from the ground up and he's has passed recently. Now it's my baby, so to speak, and i want to finish it right.
Obviously the nerf bars and window vents need to go. He even did a bed lining over the wood and everything, even the original wood. Sigh....
it ran before my dad got sick and passed but now it wont. Pretty sure its electrical.
The red will always stay, as that's what dad wanted but the white trim seems too white. I'm guessing it should be a creamier white. Anything else you can see from the photographs?
The bench seat is from some other truck and the headliner needs work too.
yea wouldn’t hurt to put them in a new thread with the title VID decode or something like that. ND will see that and decide it for you.
The pride of ownership really shows. Appears to have well taken care over the last 5 decades. The original white trim ('60-'63) on the front end was " corinthian white" a creamer shade than typical late model gloss whites. However, front end looks very sharp ( with correct black trim outline) and I probably wouldn't mess with it. However, outside mirror heads and brackets could use a color change, they were gray ( color of your inside mirror) . Also wheel color on F 350's were gloss black, so that will have a dramatic effect on the appearance also. Interior looks super clean, only change would be a black heavy duty vinyl seat upholstry with grain pattern. Power boosters or a hydrovac unit are good ways to ease the effort of braking. Biggest issue with F 350's no longer used for low speed commercial or farm work is the super low differential gears, usually 5.87 or 5.13. A good rear end shop should be able to swap out the guts of the differential with a more friendly 3.73 ring, pinion and carrier.
I searched the color code "J" and its Monte Carlo red according to the followed site. I can't tell you how happy that makes me. I wouldn't have changed the color but it would have bugged me if the truck was suppose to be green, or something, and it was painted red. Anyway, I found this link and Corinthian White looks pretty creamy to me. Thoughts?
http://paintref.com/cgi-bin/colorcodedisplay.cgi?year=1961&manuf=Ford
