Any Mods for a Ford Iron Intake Manifold?
I currently have a Fort "T" intake manifold on my 352. I know that I can get better performance from an aftermarket intake, but I don't know why the Ford manifold doesn't perform well. Anyone know? Also, can I make any mods to the Ford intake to improve its performance? It's just a daily driver, not a racer.
Joseph
Joseph
Joseph
Joseph
Also, back in the days of the Fox Chassis Mustang 5.0, guys used to send their intakes to:
Extrude Honing | Bonehead Performance
boneheadperformance.com/extrude-honing
A plastic, abrasive-laden polymer media is pushed through a part, such as an intake or exhaust manifold, clamped to the processing machine. The media, sands away unwanted material, stress risers and burrs from the internal passage ways creating a smooth, polished surface.Extrude Hone AFM - Official Site
www.extrudehoneafm.com
Extrude Hone AFM has pioneered the application of abrasive flow machining for internal deburring and polishing into dozens of industries
I'm not really bothered about the weight, though. Yes, it is @#$%&* heavy, but I have an engine hoist, and it's going into a truck. I'm far more interested in what it can or cannot do, and if/how I can modify it to perform "better" (whatever "better" means). Can I modify the plenum to improve flow, or fuel atomization, or ...? If the answer is "NO!" (or "No, and we don't understand what made you think you could") that's okay. I posted on another forum that the learning is just as important as the results (to me). I have a spare boat anchor ... oops, I mean, an extra Ford manifold ... leaning against the garage, so I'm not out any money if I screw it up, and the cost is a lot cheaper than a Performer RPM. But the only thing I can find is on port matching. Surely there is more to designing an intake manifold than that.
Any ideas?
Joseph
Any ideas?
Joseph
IMO the most advantage of the aluminum manifold is the 50 lbs you lose. If you use the aluminum manifold and the right carburetor you need headers, a cam and decent heads if you're going to see significant gains. Edelbrock has a top end package for the FE engine that looks, to me, like the thing to do if you have $2400 handy.
on
Also changing to a electric fan or even going to a clutch fan will give you a seat of the pants feel of improvements if
your doing a pedal to the metal test run..
Also change out the timing gear set to a double roller set may find new power once the oem timing set has been changed out.
Plus running straight in take manifold vacuum to your dizzy over the carb timed vacuum may show some improvement.
Orich
Orich
I've tried hooking up the dizzy vacuum can to manifold vacuum. I'm still on the fence on that one. I'm also on the Fordification group, so between all of the feedback, I'm starting to form ideas about my next rebuild. Gotta keep the stock heads, but everything else is being considered. There may be a Performer intake in my future ...
When I have my plan a little more firm, I'll ask again for feedback.
Joseph
Joseph
