Modular V10 (6.8l)
2000 V10 oil cooler leak
Old 07-12-2018, 12:15 PM
1983 F-150 300 inlin's Avatar
1983 F-150 300 inlin is offline
I replaced my engine oil cooler due to having oil in my coolant. I can not get it to seal and not leak. I have replaced the o ring with no luck. The other thing I could think of would be I have the coolant lines backwards and it is forcing the oil past the O ring. Any help would be appreciated.
Old 09-21-2018, 01:29 AM
LocoCanada's Avatar
LocoCanada
LocoCanada is offline
6th Gear
How did you get the cooler off?
Old 09-21-2018, 01:37 AM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
Did you make sure to install the top o ring dry?
Old 09-22-2018, 05:35 AM
JWA's Avatar
JWA
JWA is offline
Received 1,394 Likes on 1,103 Posts
What brand replacement cooler is that? Have not heard good things about aftermarket parts, Dorman seems to get the most mention for being problematic however that could be due that brand's general popularity for OEM-like parts.
Is the fastener holding the cooler assembly to the block tight?
If you replaced the coolant lines as they were installed on the original cooler that shouldn't be an issue.
Hope you get this solved--that would give me nightmares.
Texasdeereandhorse
06-30-2016 11:42 AM
ztodd377
11-16-2014 09:49 PM
Aune163rd
21
02-21-2012 10:39 AM
Headviking
10-21-2009 07:27 AM
Rockies
11-19-2003 07:35 PM
Quick Reply: 2000 V10 oil cooler leak
