F450 VS F350 DRW KR Comparison
Hello all i have been away for awhile.....I have had a interesting year so far......Last April i got my F350 DRW KR fully loaded. What a great truck it WAS compared to the 02 i had for 16 yrs. In February i was in northern Idaho at my cabin and rolled Woody down a ravine and totaled the truck..... thank God for the truck and airbags....made me sick, but the wife and i walked away unhurt physically, mentally still some issues for both of us, thats some scary ****.
Anyway i ordered a 18 F450 DRW KR in Magma red with the 2 tone, here are some observations and questions comparing the 2 Trucks.
I know a lot of people say they wouldn't get a 450 because its weight rating is lower, i did a lot of research on this, the curb weight of the 450 is heavier than the 350 (bigger suspension???) .....i believe that this is the difference. I can tell you the 450 is a way stiffer ride than the 350 and the spring over loads are way bigger, i haul a 5k camper (Host Mammoth) and thats the first thing i looked at. Also I still have the original sway bars from the 350.... i put on Hellwig big rig sway bars front and rear on the 350 for sway control and looking at the original 350 bars compared to whats on the 450, hands down the 450 is bigger.
The turning radius on the 450 is exactly what everyone said ....its the cats ***!!!! ALL FORD TRUCKS need this!!!!! Maybe Ford is listening ....yeah right!!
The mileage is unexpectedly higher with the 450 with taller gears, i cant explain this, it makes no sense. My average with the 450 is 13.5 MPG still on the first tank. I never got over 12.0 MPG with the 350.
The 360 degree camera is....... OK.... its cool but the resolution on the monitor needs to be improved, the 3 things i use the most on the camera system is the camera for the bed, the trailer hitch camera and the front grill camera. The down fall to this system is you cant access it while your driving (to check the load in the bed camera) you have to stop, if im stopped i can get out and walk around the truck it would be nice to be able to access the bed camera to make sure all covers are still covering and to make sure everything is riding OK while moving.
The Magma red....ROCKS.... at night it looks black, in shade it looks blackish purple and in the sun it varies from dark brown to black cherry red it just depends on the amount of sun and the angle at which you are looking at it......i have had a ton of people ask what the color is, they just love it, and the interior has grown on me, they switched the colors from 17 to 18, on the 18 the saddle (orange ) is the main color with the brown is the accents.
Now the questions
Does the 450 have the TPMS i can not find the screen that displays it ?? maybe the 450 doesnt have it ??
The tranny has a pretty loud whine at 55mph (my wife even asked what the noise was) and only at 55mph, is there a differance in the 450 vs 350 tranny ??? And the tranny seems to run about 208 * unloaded highway, 75 mph and 71* ambient air. Is the noise and temp normal ???
Injector noise in the 450 is way louder than the 350.....and most of the noise is when your driving and seems to be the passenger side, at idle its good and quite. Im guessing that all injectors are different and have there own noise characteristics????. Do they still do the old buzzz test or equivalent test for these new motors????? Should i get them checked out???? or trust the ECM self diags to flag me if something is wrong??
All in all i am real happy with the 450 and i would buy it again........but hope i wont have too. I plan on keeping the shinny side up on this truck!!!!
Pat
Now the questions
Pat
Yep, no TPMS on the 19.5” wheels.
regarding some of the other observations:
the springs and shocks are the same front and rear as the 350. Any difference in ride is from the notably stiffer 19.5 tires and the higher unsprung weight of the 450. Drop your tires to 80psi and it will help a little.
The motor and tranny are exactly the same as the 350. No difference in tuning, no difference in cab or insulation. The tires may be a little quieter than the 17s, but that probably isn’t the reason you’re hearing the tranny and motor. Might just be a little noisier one. Keep an ear on it. The 80 psi tire pressure drop may help with a speed related resonance.
Glad you love the 450. I absolutely love mine and am not looking back.
Sam
Same springs (computer selected for front). Same shocks. 6000lb springs up front (max selected). Same 480/1200/2152 lb/in deflection spring packs in the rear. Same frame and body (plus front fender flares on the 450).
If that doesn’t lower the noise, then just be happy that the truck and 6.7 are SO quiet that you can hear rubber rolling over the pavement.
try dropping to 80 psi all around. Might take some of the load off the center tread and back to a more even load across the tire.
Heard several guys here with the 245 toyo M920s on factory wheels that really like them. Not sure that would make it any quieter for you, but I think it is certainly a better tire (and size). And certainly cheaper than getting new wheels too. If you really aren’t a fan of tire noise, stay away from the M608Z. I have them and really like the tire, but they are as noisy as my 37x13.5 MTs from my last truck. Can hear them with the windows up and radio on (only because engine is so quiet)
