Does anyone have some good places to try and track down replacement exhaust manifolds for the Y block engines? My 64 has the 292 and the drivers side (p/n ece9431-b) has the front most ear broken off and it leaks like a siv. Google isn't helping much except for one ebay ad that is asking over $400 with shipping. Thanks in advance!
Rams horns are reproduced. If they are in your budget and the truck does not need to be stock, then they are a better way to go. You'll find the best quality ones here, HOME Y
NOS PARTS SOURCE in Olathe KS has 1 = 913-220-5746.
Thanks for the info, but I went and double checked the manifold when I got home and this is the number cast onto it. Is
the number on mine a discontinued one and the one you posted a revision?
Unfortunatly with a 3 on the tree the space that the exhaust pipe would go in is taken up by the shift linkages. My ultimate plan is to swap the powertrain so I'm trying not to go to crazy with this motor. I appreciate the info though.
