(Soon) Back in a Ford | 1989 E250 Club Wagon XLT
Hello!
I'm new to the forum and essentially new to ford mechanics in general. I recently sold my 1997 Jeep Grand Cherokee, which i'd had for the last 8 years and put 74,000 miles on, so that I could hopefully get into a van. I'm an overall auto enthusiast, no real brand loyalty, but my girlfriend and i do own a 2015 Volkswagen Passat Wolfsburg Edition, 1974 Volkswagen Super Beetle, 1988 Volvo 240 Sedan, 1993 Volvo 240 Wagon, and a 2017 Mazda6. This van will be my third Ford, my first having been a 1990 Ford Bronco with a 351w that i received when I was 16 (& knew absolutely NOTHING about mechanics) then sold 6 months later because i couldn't afford gas. My second Ford was a 1996 Escort Wagon my girlfriend and I purchased for the 2017 LeMons West Coast (Car Weeeeeeak) Rally, then promptly hit a deer in Illinois while driving to California.
To the present, I ended up stumbling upon a 1989 Ford Club Wagon XLT E-250 for sale nearby, which i will hopefully be picking up this weekend. It's got the 351w with a c6 transmission, and has a Gear Vendors Overdrive unit installed (but it is not working properly, which appears to be electrical.) It's also got 147k on the clock.
My goals are to build it as a road trip machine, something i can tow with, as I plan on building my Volvo to be an autoX or rallyX contender, and something I'll be keeping around for quite some time.
I'll post some pictures when I pick it up, I test drove it last night though and everything seems to be good. The steering is pretty sloppy which I'll either have to get used to or replace the steering box and some suspension components to correct it. I want my girlfriend to be able to share the driving and something like this will put her off.
If you guys can think of anything i need to check into immediately after picking it up, let me know.
I had an older Ford (1974) wagon that had a broken Rag-joint. Sometimes called a steering coupler. It's a 2 piece item which is part of your steering shaft. In my case it was broken and gave the car about "2 hrs" worth of slop in the steering. It may be your steering box or more likely a worn out front end (ball joints and tie rod ends) Hope your new find works out great for you!
This is a rag joint
This is a rag joint
This is a rag joint
This is a rag joint
BUT, alas, here she is.
So far, I've driven it about an hour or so. It cruised pretty well at 65 mph. Here's a list of the problems or faulty things I've figured out so far...
- The blower motor for the front doesn't seem to be working, i can only feel air from it when I am driving. The motor for the rear cargo area does work though. I've been looking at motors and still need to do some research but i'm wondering if it's a resistor?
- I need to secure the seat to the floor and plug up the empty holes from where the other seats would go. Currently the front seats don't match, so I may try to find a donor. Is there a guide to what will work with this van? \
- The coolant temperature gauge doesn't work, so I'll want to figure that out before any long road trips.
- Its missing its spare tire, so i'll need to find one of those.
- The drivers side window motor had stripped out gears, I found a kit online to replace those gears for $10 and I've removed the motor, so i'll be replacing that asap.
- Lastly, the Gear Vendors Overdrive/Underdrive unit doesn't work. It came already installed and wired up, it has a foot switch, I tried turning it on, but nothing happened. I'll be crawling under it tomorrow to get the serial number and hopefully will be contacting Gear Vendors in hopes of getting an installation manual and trying to troubleshoot it. I'd love for it to have an easier time at 65 mph.
After picking up the van today, the steering wasn't too awful. It took some getting used to and is definitely not my 2015 Passat, but it wasn't terrible. I may still look into getting it solid as i want my girlfriend to feel comfortable sharing the driving when we are on road trips.
Man you've got a nice looking van there!! I wish mine was in that shape!!!
The steering will never be as tight as a newer vehicle with rack and pinion steering. But you can make it better. First check over everything to do with the steering and suspension. As noted check the steering coupler for slop. Check and make sure all the tie rod ends/drag links, etc are nice and tight. Replace anything that is sloppy/worn. Make sure to check the condition of the kingpins, I-beam pivot bushings and strut rod/radius arm bushings. Any of those that are worn/bad will lead to sloppy feeling steering. Lastly if the steering box has a lot of play and it can't be adjusted out don't just replace it with a parts store reman'd box. Most of those are crap. If you need a replacement spend the money on a good rebuild like one from Red Head Steering.https://www.redheadsteeringgears.com The do a great job of not only rebuilding the boxes but also re-engineering them. So if there is a known issue with a certain box they fix that problem when they rebuild them. Lastly if it doesn't have one add a steering stabilizer kit. These also help out a lot.
On the blower motor I would unplug the connector at the motor. Then hook up a jumper wire to supply power right from the battery to the motor. If the motor runs then the problem is elsewhere. If it doesn't run replace the motor. If the motor is good, then it's time to start checking fuses, switches and harnesses. If you don't have one get a digital multi-meter and if it's in your budget a power probe is also a great tool to have.
The simplest solution for the seat is to find some factory seats and brackets out of another 3rd gen Econoline ( 75-91 ) . anything else may require some modifications/fab work to mount.
I hate the stock temp gauge with a passion! Even when they are working they aren't that great. I always prefer to run a nice quality aftermarket gauge for the water temp, oil pressure and voltage. And it's also not a bad idea to also add a transmission temp gauge too.
On the GV unit I would check the switch first. Unplug it and check it with a multi-meter to see if it's working. It may just need a new switch. If the switch is good then check the wiring. If it's good then you may need to look at the unit itself.
I have yet to look it up, but I'm guessing that the blower motor is in the engine compartment? I've not worked much on vans, but man, it looks as though it's all packed in pretty tightly. I'll probably get a chance to do this, this evening. I do have a multimeter, so I should be able to test the motor as well as test the solenoid on the Gear Vendors unit.
So far, i'm having some issues finding seats at all. Im curious if these vans are scrapped much more quickly because they're heavier. Our local "you pull it" places are just plain out of them, so I've been roving Craigslist and Facebook marketplace. Hopefully I can find something semi-era correct. I have been looking at the way the seats mount to the vehicle though and have thought about picking up nicer seats out of another vehicle and fabricating some mounts for them.
Lastly, I contacted Gear Vendors. They've given me some instructions on how to troubleshoot it and some schematics, so whenever it stops raining in Indiana, i'll get to checking it out more thoroughly.
Last night my girlfriend and I replaced the front door speakers with JVC units, we also installed a JVC Head Unit, and I fixed the drivers side window motor with a kit from Amazon. It was much easier than I expected and now the window works wonderfully!
My gearvendor controller stopped working years ago. Now I just ran a fused power supply wire from the battery to the solenoid with a toggle switch to turn it off and on. So it doesn't come on automatically with the controller. I got rid of the controller since it was kind of useless. Having the switch is ok for highway driving, but a little annoying in the city. Also, the toggle switch is better than that dumb foot pedal. The foot pedals are notorious for getting rusty and corroded. Also, i upgraded to the Maximum Overdrive Deep Sump and that was a wise upgrade. Keeps the GVOD cooler.
If you run a switch, make sure to power it to the "Key-on" power, because if you leave the OD on with the vehicle in park or off, it'll still roll. Always turn the OD off long before you are stopped. Also, never run a GVOD in reverse. I ran a NC Relay from my reverse light circuit so that whenever my reverse lights come on, it'll automatically turn off the GVOD power supply. This is more for people who are driving my van who aren't familiar with the push-button OD.
"The coolant temperature gauge doesn't work, so I'll want to figure that out before any long road trips."
Get an aftermarket gauge asap. Also get an oil pressure gauge too. The stock ones are terrible.
If the blower motor works on high only, then your resistor is busted. If it doesn't work at all, then its likely the motor. Or both.
I did find some of the van's past owners recently though. I joined a local van group on Facebook and it sounds like she's had quite a few owners. I'm thinking of naming her Roxanne.
I've ordered some gauges to monitor transmission and coolant temperatures.
I've also contacted a local automotive shop, one that i trust, to look into getting the A/C fixed/replaced on this old beast.
Last night I managed to get the Gear Vendors unit working by rigging it up with a toggle switch! I had to run power to a fuse, then to the switch, then to the gear vendors unit, then ground the other post on the solenoid in the Gear Vendors unit. It's extremely nice driving it with a fourth gear on the highway. Now I just need to diagnose the electronics. I spoke with Gear Vendors a while back and they quoted that new electronics are around $400 which is a little steep to me. I'm going to give them a call today and hope that maybe I can purchase just the wiring (it has a bunch of RJ11 connectors that plug into the control box) and maybe have it fix itself by re-wiring it with the new wires. (Thanks GenScripter)
My girlfriend and I also drove around all day Sunday in Indianapolis, checking out junkyards for seats for the van. Didn't manage to find any manual seats, sadly. It was sweltering though, 95-98 with a real feel of around 105. The van drove around all day extremely well, smelled pretty hot, i think i'm going to check the transmission fluid and consider changing out the filter in it. I think I'm also going to take the van somewhere and have the A/C system diagnosed. I plan on keeping it around for the next 5-10 years, so I think that'll make it much more bearable on road trips.
Anyway, here's a picture of my pup in the van when we visited the storage unit.
This weekend I made a trip to my hometown to show my mother and brother the van. It was about a 175 mile round trip. I hooked up the Gear Vendors unit to a foot dimmer switch left over from the original installation of the electronics for the unit. It worked well the entire trip and felt pretty good cruising at 65. I took my dog along with me and she seems to be a fan as well. At one point I even tried out the back seat. I was surprised by how well the pop out windows actually allow air to come in. I did run the numbers for the mpg throughout the trip. From Indianapolis to my hometown, around my hometown, then to Kokomo, i managed around 8.08 mpg, which is dreadful. I'm not sure what I was expecting, but I'm going to try a tune up and see if that helps at all. From Kokomo to Indianapolis, all highway, with the OD on, I managed to get 12 mpg which is better.
And since I'm treating this post as a bit of a build thread, here are some pictures from another post about me trying to solve some A/C / Heat problems I'm having and some problems and fixed I've discovered in the van.
I dropped off the van earlier this morning with the only automotive techs that I trust to look into getting the A/C fixed. I'm not sure what it will entail, but I am sure it will be expensive.
Yea, 8 MPG is way off. I got that mileage out of a 79 E350 Ambulance with a 460/C6. I get 10 mpg with my 96 E250 5.8L while towing a heavy loaded trailer. It really depends on how much city driving & idling you were doing. But with a 5.8L/C6/GV you should be getting at least 15mpg on the highway. I would give the engine a good thorough inspection and tune up. Replace all the missing/damaged vacuum lines. Make sure all the ignition components are in good condition. Replace the spark plugs, plug wires distributor cap and rotor. I would also replace the O2 sensors. Old sensors can still work but they don't react as quick as they should. And that can kill your mileage.
Also don't over look tire pressure. Depending on your tires I always run my tires at the max pressure. It's a little harsher ride but it helps fuel mileage. Mine are load range E tires, so I run 80 psi in them. You have to check the sidewall of your tires to see what the max pressure is. Then air them up to max pressure. But don't over inflate them.
It looks like some one bypassed your rear heat. They may have tried to do the same to the rear A/C. If that is the case then the bill will not be pleasant. If you are lucky you may get by with just some new O-rings, a dryer/accumulator, orifice tube and expansion valve and the refrigerant. If it needs hoses, a compressor, condenser or evaporator then it's going to get painful really quick. And it will also depend on if it's currently has R12 or R134 refrigerant.
I'm looking at replacements and trying to see which route to go. I figure if i take it to a shop (which i havent had very much luck with) it'll probably be around $300-$500. I've heard that going with the straightest route possible will help with look and i wouldnt mind a bit of a more aggressive sound, but its going to be our road trip vehicle so i dont want anything too annoying.
As far as I know, the R12 sticker is still under the hood so I assume that it is still an R12 system. Im going to work on replacing the hoses so that the rear heat does work, as far as the rear a/c, that's a whole other thing. Though if i get the front working, it may be worth getting the rear working.
There is something wrong with the van, with that kind of mileage. It could be something as simple as a sensor being bad. It could be a Bad ECT, ACT, map sensor, TPS, O2 sensors, EGR valve. If you are going to run a standard spark plug then stick with a Motorcraft. I run Platinum plugs in my vehicles just because they last longer. But my next set will most likely be a Iridium plug. They last a long time and are suppose to perform better then platinum plugs. They are suppose to give a slight improvement to throttle response and fuel mileage. I'll see if that is true or not later this summer when I put a set in my 96 E250 5.8L. My 89 E350 5.8L won't be until sometime next summer. The down side to them is they are quite a bit more expensive then standard or platinum plugs.
If you are replacing the exhaust you are either looking at a stock replacement set up or full custom. There won't be much of any direct fitment aftermarket kits for a van. The stock routing of the system is probably the best way to go. You'll have to decide if you want to run duals a single or a hybrid of the two. But even if you run true duals you'll have to run them both down the passenger side. If you are going custom I'd go slightly larger on the pipe size and go with a freer flowing aftermarket muffler of your choice. The sound is just a personal preference. Everyone has their own opinion on what sounds good and what doesn't. I'm a big fan of the Hooker Aero-Chamber mufflers. They are a straight thru design that are built like a tank and they sound good to me, without being to loud. Some people prefer Flowmasters or Dynomax, Magnaflow, etc. etc. You can go as simple or complicated as you want to when replacing a system. I prefer sticking with mandrel bends. They perform better then a standard bend. But if you are having a shop make up the system not all of them will have a mandrel bender. If you are going true duals then you could also add a narrow X-pipe into the system. It improves the performance and will also change up the sound some. But it gets pretty simple to drive up the price and complexity. Being the age your van is I would also replace the cat. I'm installing a aftermarket hi-flow cat on my high mileage 96 when I redo the exhaust system this summer. I suggest either going 2.5"( duals or single ) or 3.0" ( single ) on the exhaust system pipe size. I don't go smaller then a 2.5" on a 5.8L. On my 96 I'm running a Y-pipe into a single 2.5"to my hi-flow cat then to the muffler and out a 3" tail pipe after the muffler. I just prefer the look of the 3" exhaust pipe coming out the back/side.
If you want the rear A/C you need to do it all at once. It's all tied together.
