Rear leaf spring questions on my 95
So im thinking of getting the parts together to do my rear spring brackets and shackles
I found a kit on ebay of oe ford parts but says from 80-96 f-150 and 80-89 bronco, is this right? Or are the f-150 and bronco the same from 90-96?
Kit comes with
(2) EOTZ 5776-A
(2) EOTZ 5775-C
(4) N606109S2
(4) N801670S100
This is all i would need besides leaf spring bushings right?
Kit comes with
(2) EOTZ 5776-A
(2) EOTZ 5775-C
(4) N606109S2
(4) N801670S100
on
Every thing you have there is what you need except for the spring bushings like you said, the frame brackets are riveted on so you would need to get grade 8 nuts and bolts to install the brackets to the frame. The 90 and up F-150/Bronco is the same, different body style from the 89 and earlier.
Tidefan88
01-16-2011 10:44 AM
83 F350
04-16-2003 09:29 AM
