1978 - 1996 Big Bronco
Rear leaf spring questions on my 95
Old 04-22-2018, 06:23 AM
Fordbronco1995's Avatar
Fordbronco1995
Fordbronco1995 is offline
So im thinking of getting the parts together to do my rear spring brackets and shackles
I found a kit on ebay of oe ford parts but says from 80-96 f-150 and 80-89 bronco, is this right? Or are the f-150 and bronco the same from 90-96?
Kit comes with
(2) EOTZ 5776-A
(2) EOTZ 5775-C
(4) N606109S2
(4) N801670S100
This is all i would need besides leaf spring bushings right?
Old 04-22-2018, 06:59 AM
David7.3's Avatar
David7.3
David7.3 is offline
Every thing you have there is what you need except for the spring bushings like you said, the frame brackets are riveted on so you would need to get grade 8 nuts and bolts to install the brackets to the frame. The 90 and up F-150/Bronco is the same, different body style from the 89 and earlier.
Old 04-22-2018, 08:03 AM
Fordbronco1995
Thanks bro, just threw me off on the listing because it lists 85-96 f-150 but only 85-89 bronco lol
christurney77
1947 and Older Ford Trucks
03-01-2012 11:47 AM
buck_
02-27-2011 11:05 PM
Tidefan88
01-16-2011 10:44 AM
83 F350
04-16-2003 09:29 AM
Quick Reply: Rear leaf spring questions on my 95
