Air stuck on defrost?
Hey guys, so heres a little back story, my dad has a 2003 f350 6.8l and last year after the winter months my dad had switched his ac/heater control from defrost to ac and it took like 10-20 seconds for it to switch and his ac only worked on max ac. Fast forward some and again after being on defrost through the winter it wont switch off of defrost at all now. Fan speed works but when you move the selector it doesnt change the direction of airflow. Any suggestions on where to start? Thanks for any advice or help
Common stuff, start from the intake manifold:
Tubing near battery rots out and cracks.
If 4x4, PVH solenoid body cracks and leaks.
Leaking or ruptured vacuum reservoir.
Any other damage to the vacuum line (missing caps, vermin damage, etc) that runs from the manifold through the fire wall up to the HVAC control head.
I've lay a bet on it being one of the first two.
A hand-held vacuum pump would be invaluable if a visual exam doesn't reveal the cause.
Salomon Trujillo
07-29-2013 09:20 PM
bolingmike
07-07-2005 05:54 PM
