1983 - 2012 Ranger & B-Series All Ford Ranger and Mazda B-Series models
159 code.
Old 04-18-2018, 04:26 PM
Alex from GA's Avatar
Alex from GA
Alex from GA is offline
159 code.
I have a '94 Ranger RWD with a 4.0 and it ran like crap the other day so I read the code, 159. After doing the easy stuff, that didn't work, I removed the ECM and replaced 3 blown capacitors, reinstalled the ECM and it runs great. Got the caps @ Moser Electronics. 2 are 47u and 1 is 10u. The hardest part is getting to the ECM. I worked from the top after removing the cruise control can, 2 ground wires and the main connector into the interior. The bottom nut on the ECM cover wasn't too hard with a short 10mm socket, a u joint and a 6" extension on a 1/4" drive ratchet. Putting it back I dropped the nut and there is stays.
Old 04-19-2018, 06:45 AM
pawpaw's Avatar
pawpaw
pawpaw is offline
You get an Attaboy for not giving up & diving right in, so to speak.
I read the 159 code as MAF sensor out of self test range. So what do you suppose caused the ECM caps to self destruct??? You haven't been messing around with internet suggestions about installing resistors to change the MAF circuit readings it sends to the ECM, have you????
Goulette55
01-20-2006 09:19 PM
mikegolfnut
1997 - 2003 F150
07-28-2003 04:25 PM
Quick Reply: 159 code.
