Engine mounts, 460 in a 72
on
#1 question of the day which is VERY IMPORTANT: is it 2wd or 4wd as there is a BIG difference. There are several companies that make 2wd engine perches and 4wd engine supports such as Autofab. Just google for them.
Now, another question: will your 460 be carbed or EFI'd? If it will stay EFI'd, then did you grab the wiring harness and computer out of the other truck as the E4OD is a computer-controlled trans. If you didn't but still want EFI, there are aftermarket harnesses available. If going carbed, then you will need a trans controller such as the Bauman (which has changed names) which you can google for.
As to your other question, yes, 460's were available starting in 1975 but only in 2wd F-250/350's, IIRC, but would be very hard to find.
Just remember, this will cost $$$$.
Engine mounts
Sanderson makes a real nice compact kit, I have seen them and they are easier to install than the stock ones, I know this from past experience with the stock Ford ones.
I am currently adding a U S Shift controller to control my Coyote project. They are very nice to deal with and have good support.
on
on
Your google-fu is not very strong.
Here are two:
1965 - 1979 Ford Truck 2WD
Mounts W/ Stands Early 2WD 67-79 Trucks
Search the rest of their stuff.
Here are two:
I had a 72 and put some FE style motor mounts in.( a single stud for the motor mount) And used the stock 390 towers I believe the company was L&L. Do your research, another company had bad reviews in the vulcanizing process. Ford could not meet emissions so they did not put 460 in a 72. I tried using the 2 piece mounts..The ones that the bolts cross. I had to change the oil pan ,pump screen ect. I changed from a front sump to rear sump oil pan. Make sure it clears the center drag link on your turns.
on
You need the perches to mount the engine onto without hassle. Look at what you have now. The engine mounts only connect the perches to the engine. The perches are designed to fit without problems except to drill new holes in the crossmember. Why do something 1/2 A.... with trying to use other engine family perches.
on
Yes, for Bumps (67-72)/Dents (73-79) there are different perches for the different engine families. FE/Big Six; 302/351M/400; and 460. 80-96/97 (as 98's were diesels only for fleets) are totally different architecture. Not a bolt-on deal unless you can fabricate. The best way to go would be the manufactured perches and the mount kit as they would be compatible together. Get the complete perch and mount kit. With other perches you would have to play with them to get everything lined so why go through the hassle.
Comparison Photos of Engine Perches - FORDification.com
