Motorcraft 2150 power valve
I also have a rich condition when idling and adjusting the idle screw mixture inward doesn't seem to have any effect so I was looking for more evidence that the power valve was leaking before pulling the carb. I noticed the fuel is disappearing from the bowl after a short amount of time and thought it may also be power valve related and wanted to ask. Looks like I need to pull the carb and test the power valve.
On second thought, before pulling the carb I think I'm going to use a clamp and clamp the line shut so it can't go back toward the tank and see what happens.
Thanks for the reply.
Maybe only the fuel supply line up to the carb but never the carb bowl.
Look where the float needle is, yes at the top of the bowl. There is no hose to the bottom of the bowl from the needle and seat or fuel supply line.
So it is either boiling out when you shut down the hot motor OR evaporating OR drain out thru a bad power valve.
If running rich I would go with power valve.
Dave - - - -
How long does it take before it drains out? If it's about a week, then it's usually evaporation through that large port on top of the carb that used to have a hose on it. Here we go again, but if these are the symptoms, plug that hose port off on top of the carb and see if it cures the problem.
Matthew, I do not feel like it today, I am not saying anything.
Closing the idle mixture screws does necessarily mean you will stall the engine. If you are running off the transfer slot or the mains the idle mixture screws will do basically nothing.
In other words, the carb butterflies are open too much at idle for some reason. What is your idle speed?
I set the idle down to approx. 600 rpm before closing the idle screws. It just was idling without stalling when I turned the idle screws all the way in. I let it idle for a good 5 minutes with the screws all the way in before cutting the ignition. When I pulled the carb and opened the housing that contains the power valve, I had a good bit of fuel run out. To me that means that either the valve has a leak or the little gasket around the neck of the power valve is leaking. Not sure which. I rigged up a hose from the bottom of the power valve and used a vacuum gauge to try and pull a vacuum and I never could get any vacuum to hold.
