Another electronic to manual transfer case thread...
Old 02-23-2018, 11:33 AM
StrokinHer01's Avatar
StrokinHer01
StrokinHer01 is offline
https://m.ebay.com/itm/NP271-Case-Fo...AAAOSw5utaic8X
ive heard that the fork inside the electric case will not work if one tried to do a manual conversion. So I found this and started wondering if I can take my electronic case apart and put this inside and get all the linkage and be good... seriously what is the differences between the 271 and 273?! Any conversion write ups would be nice
Old 02-24-2018, 12:20 AM
aawlberninf350's Avatar
aawlberninf350
aawlberninf350 is online now
It's a Van Gogh
No clue here sorry, but I can bump ya.
Old 02-24-2018, 08:06 AM
cleatus12r's Avatar
cleatus12r
cleatus12r is offline
Butt-Head
Received 1,995 Likes on 1,120 Posts
The differences:
Front case half/lever shaft assembly with the "rooster comb".
Find a salvage/wrecking yard 271 front case half and you're golden (or just find a good used 271 if you don't feel a transfer case disassembly/reassembly is in your skillset).
The hardest part of the swap is finding and installing a good shift lever boot and punching out the glued-in floorpan plate where the lever comes through the floor. Also, the switch wiring that "tells" the dash bulb and PCM that you're in 4x4 or low range is non-existent in an electric shift truck where all that information comes from the GEM oor the 4x4 Module (depending on the year 99-01 or 02-03).
It's NOT a straightforward swap and is not for the faint of heart if you want it done right.
Old 02-24-2018, 08:51 AM
SaintITC's Avatar
SaintITC
SaintITC is offline
I wasn't aware that there was an input to the PCM for 4x4. If someone converted from 2wd to 4x4, would they need a new PCM? I was about to do this to my '97 before it got whacked.
Old 02-24-2018, 09:26 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
The only reason the PCM cares about the transfer case mode is for low range so the shift points can be adjusted accordingly. Manual transmission pickups aren't so finicky.
Old 02-24-2018, 10:24 AM
StrokinHer01
Old 02-24-2018, 01:35 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
So if you already had your answer, why'd you bring it up here?
Old 03-21-2018, 11:34 AM
vroma's Avatar
vroma
vroma is offline
What about a manual-to-electronic conversion? Has anyone done this?
I would not mind losing the floor shifter...
Old 03-21-2018, 11:58 AM
SaintITC's Avatar
SaintITC
SaintITC is offline
Read Cody's first post (#3): You'd need to do the opposite, which actually sounds even harder. Finding the dash switches, GEM or 4x4 Module, the floorpan plate. I suppose all the automatic hub stuff if you've manual hubs - don't know if electronic shift was available / possible with manual hubs.
Old 03-21-2018, 12:21 PM
StrokinHer01
you sir, are a butthole!! I’d take you floor shift any day
Old 03-21-2018, 12:24 PM
StrokinHer01
Since it looks like I’ll have to keep my toggle switch set up for awhile does anyone know how to make the gauge cluster lights come on when I put it in 4x4???
Old 03-21-2018, 12:43 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Not going to work on a 273 without a functioning GEM/encoder. No place for the manual switch from a 271 either.
Old 03-21-2018, 02:09 PM
DogRidesInBack's Avatar
DogRidesInBack
DogRidesInBack is offline
Actually, I would not mind having hubs I could lock without getting out of the cab, but other than that I do not mind the floor shifter. I do mind my current options:
  • Stop at the bottom of the mountain to lock my hubs each time I go home, and again each time I go out
  • Drive with them locked which costs fuel economy
I think I would have to swap front axles and buy a bunch of other parts to convert, which would cost more than the fuel I'd save.
Old 03-21-2018, 02:31 PM
SaintITC's Avatar
SaintITC
SaintITC is offline
I'm an old school kinda guy, I don't mind getting out and turning hubs when needed. What I do miss is the LS rear from my '97 2WD F250, never needed 4x4 then. Now I get stuck in my driveway - open diff in this 4x4 truck - but I think it tracks better on snowy roads. The 2WD drive was fun on exit ramps, I could always get that back end sideways in the rain!
Old 03-21-2018, 02:36 PM
DogRidesInBack
I have LS, and there is one curve climbing my hill where I spin both rears in 2WD, Need 4WD to pull around that corner without sliding sideways into the ditch.
Quick Reply: Another electronic to manual transfer case thread...
