1992 f250 engine not getting to hot operating temp in cab heater does not work
1992 f250 351 motor 4 x 4 111,000 miles
Ok so recently I noticed the temp gage slowly creep up to 3 hot this is too hot for normal but it would not over heat. It would go down to 1 hot and then back up slowly. About that same time the heater stopped working in the cab.
I thought thermostat so I changed it. Now the motor will not get hot the gage barely moves.
I have tried a few things after reading boards, ralking to friends and talking to the guy at the parts store.
I changed the blendor switch motorcraft part number yh-530. Did this thinking posible vacume problem for heat in the cab. This did not bring the heat back.
I flushed the coolant system with an at home kit. Everything in there was very dirty no chunks though seamed like no plugs. Also took the garden hose off to see how the water pump was pumping, this was on the heater hose, and it seamed to be pumping enough.
I put a piece cardboard in front of the radiator this did get the motor hot above 1/2 hot on the gage bit the heater in the cab did not get hot still.
I don't know what to do from here Please help.
It sounds like your new thermostat is defective, what brand was it? Only a genuine Ford thermostat is recommended. After you get the thermostat squared away, if the heater still doesn't work good you would need to flush just the heater core or if that doesn't help replace the heater core.
jamanta
1999 to 2016 Super Duty
13
11-03-2017 12:19 AM
kolb02
01-25-2008 12:52 AM
luke_trash
11-24-2003 07:57 AM
