Alternator recommendation.
I know the subject has practically been beaten to death, but I'm hoping someone has straight forward info for me. Even if that's a link to archives.
I have an 06 F250 that tows a toy hauler a bit, and has a slightly upgraded stereo system.
I'm on a limited budget, but obviously don't want to worry about having to sink more money on a new alternator every year. So, practical advice would be much appreciated!
Man, I can't tell you how much I appreciate your fast and straight forward answers. I've been putting off the alternator for a couple weeks, because I had to drop a boat load of money on a few other things, but now my headlights are pulsating and battery light is periodically flickering. I'm doing the scramble as to not get stranded and it seemed like the more "research " I did, the more conflicting the answers I got. So, many thank yous kind sir!
It does. For whatever goofy reason, maybe that it’s a 140a rather then 110a, it keeps coming up with that. I’ve actually bought two, installed the last one for a guy who used to have a 6.0. The only issue you may have with a latter year truck is your alternator post may be clocked more towards the drivers side, so massaging the cable may be needed. Or if your comfortable, reclocking the back of the alternator case.
Some later model trucks came with the 140a, so is this a replacement because of issues or are you looking for more power?
And a vid about what you’ll need to do to flip to the smaller pulley.
I just put the same one back on, but you get the idea. When your flipping alternators to prevent a short all you have to do is remove the small cable that booths to the top of the passenger side battery terminal. That disconnects power to both “hot” leads to the alternator. 10mm I believe. Just make sure you reinstall it before starting the truck.
And not that you need it but good info for the situation your in now.
He'll be fine with the stock belt and tensioner. Consider also at least the hot side upgrades in Jack's thread in the tech folder:
https://www.ford-trucks.com/forums/1...tery-life.html
And for goodness sake have both batteries load tested. Bad batteries can take down a good Alternator as a Bad Alternator can kill good batts. And either or both can kill a good FICM...
And Y2K really is a good guy, sometimes comes off a bit gruff - I'm going with had a tough childhood or spent too much time working on 7.3s...
Scott
Scott
