Fuel trouble - '92 7.3L IDI
Good morning all,
I'm having a hell of a time with my '92 7.3L. Last weekend, I decided to finally fix the issue with the fuel tank pickups rotting away and replaced the little showerheads with new ones. Cleaned up my sending units, had the bed off and everything while I was down there.
The problem is, now I cant get it to drive!
I have been able to get it started (which was an ordeal - battery cables, two batteries, and a starter later!). I cannot seem to get it to actually drive without stumbling/hickupping/surging like crazy. Cant get it to go over 35-40MPH. I have noticed at idle that no fuel comes out of the schrader valve at the filter head - and I have installed clear lines to observe air in the fuel at the return line/filter head hose and injection pump/return line hose. I do not see fuel coming out of the orifice fitting at the filter head through the hose either. Any ideas??? I am at a loss. I replaced my mechanical lift pump through this, and I have blown out the lines for restrictions as well to see if they were restricted. I have a video of the truck running as well.
Even if you have double hose clamps on a fuel hose going into the lift pump, if the fuel hose is 30 years old you will get air intrusion through the hose itself. Make sure all the hoses have been replaced.
Hmmm...
You mentioned that you just replaced the lift pump. If you feed the fuel IN to the lift pump from a jerry can and there still isn't fuel coming from the schraeder valve at the fuel filter head then perhaps there's a restriction between the lift pump and fuel filter head. Did you blow out that line as well? Did you replace your fuel line olives?
Hmmm...
I did not - I was just thinking where else this problem could be steming from. I already remember a few months back, that I refilled the tank while the truck was running and I was getting bubbles out of the heater element connector on the head - I was not able to get the connector off though! It is really on there. I am thinking about going through this whole top end again for intrusion.
You may be able to disassemble the fuel heater connection by soaking it with cleaner daily for a week or more. Use an old toothbrush and clean the grime off of it so your cleaner of choice can penetrate better. I was able to get the glow plug controller out of the driver's head by using plenty of PB Blaster and PATIENCE. Give Simple Green a try. Good luck.
Good afternoon all,
Figured it out (to an extent).
Took the fuel line before the lift pump and blew it out thoroughly with an air compressor.
Got great results! Truck ran great. I blew whatever sediment/restriction back into the tank
And about 5 miles down the road, I was right back where I started
So I'm going to order two new tanks to rid myself of this trash.. Has anyone got a good link to swapping in a Bronco rear tank?
Unless you really want to go through a tank swap consider restoring the tanks in the truck. This stuff works great. I've used it on my Olds and on my truck. You can probably restore any tank as long as you aren't way up north where the salt made the tank look like swiss cheese.
https://www.summitracing.com/parts/poi-49239
See the tank here @ ebay:
https://www.ebay.com/itm/231020763763
