Does someone have a picture of how the pedal sheet-metal is attached? The picture I have has a mock up of the two pieces of sheet metal, and the seal. I was wondering how the two thinner pieces of sheet metal are attached. Thanks.
I have trouble with those every time I take them apart. These pictures probably won't be of much help, but a couple of the metal pieces go on first, then the seal, then the rest of the pieces. The trick is to figure out the correct order for putting in the screws. Good Luck! - Bob
