96 F-superduty 7.5 misfiring at idle
Old 09-25-2017, 12:11 AM
jtmalott's Avatar
jtmalott
jtmalott is offline
96 F-superduty 7.5, E40D
241K miles
I am noticing a slight misfire when idling, and sometimes under a load, almost like pinging. I have just replaced some horrible plugs, wires, and cap. I have no CEL, and no codes with a reader. The smog pump has been bypassed and the cat is removed and replaced with a pipe, and straight piped back. The misfire causes a slight rumble. What should I look for, or is this normal wit a motor with this many miles? She has plenty of power, as I frequently tow 8000 pounds with it. I get about 8 mpgs, which I understand is normal. Thanks in advance.
Old 09-25-2017, 11:05 AM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,164 Likes on 919 Posts
I thought you had your issue(s) resolved https://www.ford-trucks.com/forums/1...gher-rpms.html
Old 09-25-2017, 11:26 AM
jtmalott's Avatar
jtmalott
jtmalott is offline
Yes, mostly. Or so I thought. Truck it's a night and day difference from before, so I decided to start a new thread. This is more of an annoyance than a performance issue. Not sure if I even want to chase this problem. I will check my plugs after a few 100 miles to see what they look like.
Old 09-25-2017, 07:27 PM
Lead Head's Avatar
Lead Head
Lead Head is offline
What is a rumble?
Old 09-26-2017, 11:27 AM
jtmalott's Avatar
jtmalott
jtmalott is offline
Rumble:
motor jolts one way or another out of balance, possible from a misfire. Can hear it in the exhaust too, instead of blub blub blub it goes blub blub glub gnawadimean?
I'll get a video and post it
wperillo
10-20-2017 02:20 PM
SLE
Modular V10 (6.8l)
03-22-2012 08:18 AM
gabebdog1
1983 - 2012 Ranger & B-Series
08-17-2005 06:10 PM
Andyman8282
01-26-2004 09:05 PM
Drexx
01-12-2003 06:02 PM
Quick Reply: 96 F-superduty 7.5 misfiring at idle
