OBD2 scanner recommendations
on
on
If you plan on using Forscan to do any programming to your truck along with reading codes I suggest;
OBDLink MX Bluetooth (recommended) https://www.amazon.com/ScanTool-4261...dp/B006NZTZLQ/
bbfly ELM327 Bluetooth V1.5 modified https://www.amazon.com/gp/product/B01MUALTSX
OHP Ford ELMconfig USB https://www.amazon.com/gp/product/B01F0GVBWY
VINT ELM327 USB https://www.amazon.com/dp/B01N18TOFB
JD...I would like to use forscan. Is there an IOS compatible device that you recommend? Maybe this one? https://www.amazon.com/BlueDriver-Bl...ywords=Obdlink
Forscan tutorial https://docs.google.com/document/d/1...gF1wxIqxY/edit
If you want something to keep with the truck, look at a ScanGauge II. I've used one for years (the same one) on multiple rigs and it works great. Also provides four additional gauges when you're driving, which is nice to have as well. It isn't as useful as FORScan, but they're two different systems for different applications.
James Baldwin
01-07-2013 11:10 PM
terramir
07-03-2008 11:13 AM
mr_al
11-21-2007 12:28 PM
