Injectors not kicking in.
I have a 1988 f150 with a 302 that I purchased and wasn't running and sitting for 8 years. I replaced the fuel tank, fuel pumps, and filter and can't get it to start. The fuel pump primes and will turn on with started fluid but won't stay on. I'm lost and don't know what to check next
Sticking injectors
I've used XLT's technique as well, but just sprayed carb cleaner directly into the injector. On stubborn ones I applied 12 volts.
Some I had to tap with a chunk of brass while applying the electricity. After freeing up, they all displayed excellent spray patterns.
If you have access to an ultrasonic cleaner, it will free up the injectors as well. I just use dish detergent and water as a cleaner.
There will probably be small amounts of goo and varnish in various parts of the fuel system even after changing all those parts. My recommendation is to put only one or two gallons of gasoline in, then add one or two quarts of pure isopropyl alcohol to dissolve the gum.
There is also a 70% isopropyl alcohol sold, do not use it as it won't mix with the gasoline. If in doubt, mix a bit in a bottle with gasoline before adding it to the fuel tank.
76fordman
05-31-2004 05:14 PM
