Heater Valve
Heater Valve
I tried to search on this site for an answer, and I've googled it a bunch of times, but I can't seem to find the part number for this specific valve. I'm not sure if it's from the 74 302 that someone put in this truck, if it's an original from the 64 flareside it's in or if it's from some other vehicle.
Note the threads on the inlet or outlet (not sure which yet, but it's the connection on the right side in the picture, going to the heater core).
Can anyone help?
Can anyone help?
Part number originally was
B8C-18495-A
You can search the forums on that number to read some other posts. It looks correct to me.
However, check that connection again. Most of the gold/red/blue nut looking ends for the stainless braided stuff is just for looks. A cap that covers a typical clamp. I suspect both sides had the cap and the lower left is just missing it.
Let me know if that didn't make sense and I'll try to clarify my thought.
Chad
B8C-18495-A
Chad
This is fuel line, but same deal as far as the ends go. Look at it real close and, while this is an improved design from years past, you can probably see the built-in clamps.
https://www.summitracing.com/parts/mrg-1526/overview/
Chad
Chad
No factory A/C, no heater water valve.
Original valve has two nipples, one points outward, the other is 90 degrees away on the side. The mounting bracket is made as part of the valve.
B8C-18495-A .. Heater Water Valve-Use with fresh air heater. Valve located on fender apron (Motorcraft YG-134) / Obsolete
1957/60 all trucks except B500/750 School Bus & P100/500 Parcel Delivery / 1961/64 F100/1100 / 1963/64 N/NT500/1100.
I'll list sources for this valve tomorrow.
Here's one on eBay. The seller needs to put on his spectacles because the box says B8C-18495-A not B8C-18455-A as mentioned in his ad. You *might* find one for less, but $20 plus shipping doesn't seem too bad. The bracket seems integral with the valve, to me anyway.
I searched on YG-134 to find this one. That's the Motorcraft number.
Coolant control valve b8c-18455-a fits 1958 car I think new controls heat
Chad
Chad
1973/79 F100/350 & 1978/79 Bronco have a vacuum controlled heater water valve if they have factory installed integral A/C.
Original valve has two nipples, one points outward, the other is 90 degrees opposite on the side. The mounting bracket is made as part of the valve.
MARK II ENTERPRISES in Apple Valley CA has 5 = 800-576-2752.
Chad
Chad
