Stance and wheel and tire size
Hey guys. I have a 1973 f100 2wd swb I would like to find some photos of various wheel and tire combinations. With details. Offset/backspacing/wheel width ..all the details. I like a fat tire in the rear tucked under the fenders. I'd like to see some detailed pics. I will likely be using the dream beam drop. It's currently lowered the old fashioned way. Cut springs in front and pulled leafs in Back. But I wanna do it right this time and get rid of those bowed in front tires.
What look are you going for? I'm swapping out my old suspension for 4 wheel independent. All 1995 Jaguar independent suspension. I've already purchased my old school looking coke bottle American mag wheels. I haven't purchased the tires yet. My wheels are 20x10 in the rear & 18x8.5 fronts.
I think I'm going to run 255x35x18 front & 315x40x20 in the rear.
I don't have any ictures of it yet.
. Where abouts do you live. I just took off a set of brand new Dream Beams if you are interested?
I have pictures of the truck with a flu kit & the dream beams with 15 inch wheels on it.
. The only reason o took off the beams was because it just wasn't low enough for me. Plus I wanted to bag it front & rear.
. Good luck. Let me know?
Pictures
My 73 with Dream Bems & Flip kit.
I took it all out. Putting in all IFS & IRS now.
I just pulled my brand new DIM Beams. It also is a flip kit in the rear. I just pulled it out in my yard. Took a good look at it. Didn't like how low it was. So I drove it bc K to my shop. Set it up on stands an cut the front end off of it. As soon as I get the front Jaguar XJS suspension installed in the front. I'll flip it around & install the Jaguar IRS.
I'll try to get some pictures up with the Beams an flip kit under it.
. Anyone out there doing either the crown Vic or Jaguar independent front suspension?
running 245/45/20 all around!! Cut 1-1/4 off of new springs for a F-150 with a 460 !! Pulled the thick bottom load leaf !!
I've received a lot of compliments on my combo. '77 f-150 all stock springs, it has the HD rear springs so it sat like 3-4" higher in the rear stock.
DJM dream beams and a DJM flip kit in the rear (dropped 5.5") with a suicide doors c-notch welded in. Wheels are old superior turbines, 15x8 with 3-3/4" or 3.5" backspace.
tires are front 215/70r15 and rear 255/70r15
