Belts chafing
Belts chafing
Hello all,
On the engine (7.3L IDI) from my 1989 F-350 I have the crank-power steering belt chafing against the crank-AC compressor belt.
That made me change those belts, and with the new belts they still were chafing, in mid air where they cross each other.
Then I put some washers behind the power-steering pump and the bracket, with the idea to generate some more space between those belts, and after a good 50 Miles we're back to start, and they are chafing again.
Is this a known situation? and does someone have a better solution instead of my washers?
Any advise is welcome!
You are correct, out of my head, (I did the washer thing almost two months ago) the power steering pump is too much forward.
By undooing the bolts to the pump, and put one or two washers underneath and reinstalling them, I thought to have corrected that situation, giving more space between those belts so that the chafing should have stopped.
but 50 miles down the road, I'm back at the beginning
It sounds like you pulley has slipped back some. It is a press fit. It takes a special puller to get it off. It not hard to get off.
When I changed mine. I got the pulley close before I nstalled the new pump, then use a bolt , a nut, and big washer to move the pulley into position for proper way alignment
https://www.amazon.com/Astro-7874-Pulley-Puller-Installer/dp/B00061SGTK/ref=sr_1_3?ie=UTF8&qid=1501233621&sr=8-3&keywords=power+steering+pump+pulley+puller
I've searched for that tool, Amazon does not ship to France, and over here I can buy the same tool for 120€ is almost 120$, so that's a nogo.
I've also had a look at my pump/pulley, and it seems to be really well attached, no signs of deplacement/slippage or the like. are you sure in that you think it came loose
No I am not 100% but unless the mount is bent which I doubt they are the only other place that affects belt alignment.
It may not be alignment it may be one or both belts are too wide. You can go to a narrower belt it will just ride a little lower in the pulley
https://www.rockauto.com/en/catalog/...e,belt,8900://
Ambulance belts could be differant only for alt. But there is a 15/32(11.81 mm) and 1/2 "(12.7 mm). Since they are close to each other that could be the problem
https://www.rockauto.com/en/catalog/...rive,belt,8900
1996F150XL
05-28-2014 10:37 AM
Old and Busted
11-17-2008 02:20 PM
ferguson777
32
03-19-2004 12:22 PM
