check RPM's with dwell,tach, voltmeter?
Old 07-22-2017, 10:45 PM
annaleigh's Avatar
annaleigh
annaleigh is offline
I am checking the pressures on my AC system and the manual calls for the engine to be idling at 1500 rpm's. I have an old dwell, tach, and voltmeter. The instructions with the meter say it will work with a Ford TFI ignition from 81-86.
Before I take the doghouse cover off to access the coil, can anyone verify that the meter will work on a 88 E150 with fuel injection?
Didn't fuel injection come out in 85 for F series trucks?
I would think it should work but just wanted to check first..
Thanks
Anna
Old 07-23-2017, 12:23 AM
quaddriver's Avatar
quaddriver
quaddriver is offline
the old meters need either a hot side and a tach signal, or a ground and a positive tach signal.
the EECIV coils had 2 terminals going to them that should suffice. I recall using an old sun or actron or something tool years back (now I just ask the ecm....scan tools are cheap)
Old 07-23-2017, 12:57 AM
annaleigh's Avatar
annaleigh
I think mine is a Actron.
What is a cheap scan tool to use on 1988 OBD1 that will read out live info?
Snap On MT2500 is the only one I know of..
czrider
04-30-2018 10:18 AM
kfcoltn
01-11-2010 12:52 PM
Jermafenser
Garage & Workshop
08-03-2009 06:02 PM
Beastmaster
12-30-2005 03:19 PM
shorebird
Modular V10 (6.8l)
03-19-2003 12:19 PM
Quick Reply: check RPM's with dwell,tach, voltmeter?
