Dakota Digital VHX gauges
Received 4,132 Likes
on
on
Is it accurate..? Mine is reading faster than what I'm traveling and the needle bounces back and forward. We did the Auto Calculate then tried fine tuning it by using the GPS and that was insane and ended up doing the auto cal again . I have a new sending unit for a Bronco that is 73-10 ohm and neither one of the set Ford settings work..
on
on
I'm going to go over my wiring again tomorrow. Did you just run one wire to your tank and ground the tank to the frame or run the ground wire with the signal wire to the control box. I twisted the 2 wires together from the sending unit to the control box, I'm wondering if I should change that..
on
I have Dakota Digital cluster in my 56 but it's not the VHX version. I did buy that VHX system for my 40 Ford however and had pretty good luck with getting it dialed in. That said, I haven't driven it yet but I did run it with the wheels up off the deck and the speedo did go up and down with the RPMs of the engine. I am amazed at how technology has made our vehicles more reliable and fun to drive while still preserving the vintage look and feel.
on
I just read the troubleshooting and at the top they talk about the grounds and I know you have grounded it good just saying
