Transmission won't shift into higher gears
Hi guys! I have a 95 F150 with the 4R70w transmission. I was coming home on an hour long drive and my truck shifted very abruptly going up a steep hill. (I was doing 65-70 mph). Then the overdrive switch on the shifter started blinking OFF. About 10 miles down the road, I stopped my truck and did a restart and the light turned off. I could kind of smell transmission fluid when I stopped. A few miles more down the road and my truck stopped shifting over 60 and then later it would not shift over 50 mph. I limped the truck home my shifting it from N to D which help get it into gear when I lot it. Transmission fluid level is good too.
The transmission was rebuilt 15,000 miles ago and I did have this same issue before when the transmission filter came loose.
Does this sound like the same problem?
Any help would be appreciated!
If there was an issue to trigger the O/D light to flash it will be stored in Continuous Memory (CM aka Stored Codes). Therefore regardless if the O/D light is no longer blinking or the Check Engine Light is off there will be a code stored in memory.
You can use a paper clip to pull the codes: How To Run a Self test
Or do yourself a favor and purchase a code reader such as the Equus/Innova 3145. It's a worthwhile investment.
So other than the obvious fact that my transmission is overheating. What would a temperature switch be?
The code 68 description is transmission temperature switch circuit failure; circuit open.
Do you happen to know what it means off the top of your head?
ok I figured it out. The extension cable I bought with the innova was bad. So I ran the codes and it gave me 565 O. That code in the book is canister purge solenoid circuit fault. I'm going to look up what that means.
The KOER test was good. No fault codes.
Nope gave 111 for C.
At this point you should probably just drive it again til you get the flashing light. The hard shifting is not a problem but a deliberate feature intended to protect the transmission. Aside from being a little harder on u-joints it won't hurt a thing. If it were my truck I'd go for an easy ride and see if the fault comes back. If not then put a little more load on it, maybe drive up the same grade you were on when the problem first happened.
I know the code 68 you got was erroneous, as mentioned above, but since you asked... there is no temperature SWITCH in a 4R70W that I am aware of. It is a PTC thermistor which is an analog device so it will provide an actual temperature value to the PCM (Powertrain Control Module).
Today, I disconnected the cooler lines and checked the flow of the fluid through it. It worked pretty well. However the fluid might be the problem.
Here's a picture of new fluid next to what's in my trans:
I'm not sure what qualifies as burnt and therefore ineffective fluid, but the current fluid looks aweful black compared to the new. The current fluid also smells bad.
What do you think? Could burnt fluid be the culprit after all?
I bought a new shift solenoid. I'm going to install it and see what happens. No codes came up for it, but the symptoms match.
