302 to 300 Swap
302 to 300 Swap
Hey guys my truck currently has a 302 in it that gets 12mpg. I am looking for more low end torque(and hopfully mpg) and have found a parts truck with a 300 and a 5 speed in it. The parts truck is an 89 so I am pretty sure it is fuel injected. From the research I did I will need to switch the motor mounts but the trans mounts should be the same. Is there anything else I should know about this swap? Will I need the driveshafts changed at all? Is there any performance mods I should do to the motor while it is out? What does it take to get 200hp out of the 300(what the 302 makes stock)?
on
What year is your truck? If it's a '96 as your handle indicates this is a complicated swap with the truck being OBD2, You really need to source a '96 300 for all the 1 year specific parts it has.
If your 5.0 only gets 12mpg there is something wrong with it, it should do much better than that unless you only make shirt trips and it never gets up to operating temp. If that is the case substituting a different 300 cu in motor in won't help the situation.
on
That means the truck is OBD2 and the PCM connector is 108 pins, the OBD1 PCM only has 60 pins.
The engine portion of the harness is different for each engine but the PCM connector is the same except when they switched over to OBD2, then everything is different. So yes if you had an OBD2 PCM for a 4.9 it would plug in but you don't so this is a complete no go.
Its has 265/75/r15 tires(about 31s). It has no lift and 3.55 gears. The check engine light is on somthing to do with the egr, is this making that much of a difference?
I can get the exact codes later, I believe I was getting both egr flow insufficient and excessive. I was also planning to do a compression check somtime this week.
I am getting three codes, 401(Egr flow insufficient) 411(air injection flow incorrect) 136 (o2 sensor bank 1 sensor 2)
on
So you have at least 2 problems, the O2 sensor problem itself could be enough to keep the PCM in open loop and that would definitely impact fuel milage. Bank1 sensor 2 would be the downstream sensor though, do you have an aftermarket exhaust on the truck or have the cats removed?
Code 401 is telling you the EGR system isn't working correctly, the DPFE system on this truck measures gas flow through the EGR tube so you could have a bad control valve or a broken vacuum line between it and the control solenoid, or a faulty DPFE sensor.
Code 411 confuses me, I didn't think these OBD2 trucks had an air injection system. Does your truck have an air pump?
