Seized Drum...
Old 05-25-2017, 07:35 PM
jakeharp's Avatar
jakeharp
jakeharp is offline
Seized Drum...
Yup I know.... Lots of videos and reading and im doing that also... It seems to be hung up right under the cylinder, I can pull the bottom of the drum out enough to actually get some light into the drum, but she is frozen on top..... Dana 60 Free Floater rear .......... Anything im missing hear ? The star wheel will only adjust UP for tightening and not down for loosing, its frozen in that direction.... This is why I put off this project for so long, I knew I was going to be without my truck once I started
Old 05-25-2017, 08:08 PM
jakeharp's Avatar
jakeharp
jakeharp is offline
Cool Got'er
Took a little sweet talking........ But I got'er off, is it supposed to look like this ? Just hope I can get the dam thing back together ! The only thing worse than this brake is the sticker on that jack....... was a gift I promise....
Old 05-25-2017, 09:12 PM
PapaBearYuma's Avatar
PapaBearYuma
PapaBearYuma is offline
Looks to me like you're missing some springs. Should be a big spring at top, and another at bottom, to retract the shoes. Probably why you couldn't get the drum off.
Looks like the shoes are worn pretty thin...
Here's some help: http://www.boyandjeep.com/tech-artic...-60-rear-drums
Old 05-25-2017, 09:24 PM
jakeharp's Avatar
jakeharp
jakeharp is offline
Thanx
Thanks PBY, yeah there was one big long spring laying in the drum and a piece of another that fell out .... Doing a total rebuild to include new drums, cylinders etc...... gonna be a learning experience, but that has been the story of this build and I do after all enjoy working on the truck although I was wishing the brake fairy would have broken into the shop and got this done in time for the holiday weekend... but it didn't happen
Hey that article rocks ! its a keeper, building my confidence up as I read it.
Old 05-25-2017, 09:30 PM
PapaBearYuma
These brake jobs aren't nearly as hard as we make them out to be. The hardest part is bleeding the system by yourself...
But don't try this job without the proper 2-9/16R socket!
Yep, that's a great article-it helped me a lot.
Last edited by PapaBearYuma; 05-25-2017 at 09:32 PM. Reason: Added comment on linked article
Old 05-25-2017, 09:31 PM
meangreen92's Avatar
meangreen92
meangreen92 is offline
Biggest piece of advice is to not get those star-wheel adjusters crossed up from side to side. One side is standard thread while the other is reverse. I forget which is which...
Old 05-25-2017, 10:03 PM
jakeharp's Avatar
jakeharp
jakeharp is offline
copy
I read about the re-verse threaded star wheel, my kit came with color coded everything, for mechanically challenged folks like myself.... Hopefully I can pull this off this weekend, gotta get the bearings and seals tho... still pining down the part#s and kits for those, theres gotta be a complete seal and bearing kit right ? How many millions of Dana 60's were made.... Someone confirm Timken Set38 for both inner and outer bearings ? Also, the diff oil lubes the free floating bearings correct ? No need to pack bearings ?
Old 05-25-2017, 10:11 PM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Once ya get into it, will make sense. The star wheel always turns "down" to tighten the shoes, as you look at it from the outside, as in the pic. Not a lot of meat left on those shoes!
Old 05-25-2017, 10:23 PM
PapaBearYuma
The self-adjusters are unfortunately designed, in that they fit left or right, forward or backward. Four directions, but just one correct...
Old 05-26-2017, 11:03 AM
dads1977's Avatar
dads1977
dads1977 is offline
Following for
Old 05-26-2017, 05:54 PM
jakeharp's Avatar
jakeharp
jakeharp is offline
Baby steps
Got the thing apart, didnt take much it fell apart in my hands, shoes came right off.... I got the backing plate cleaned up a bit, and the new cylinder installed, struggling with the star wheel.... Want to get it right the first time, and the adjusting levers in the bags are labeled L and R, but playing with the starwheels im still confused as to if you want up from the diff side to tighten or loosen the shoes ..... and its funny with every forum post ive read there are several contradictions in posts, got a feeling lots of folks driving around with the star wheels on backwards....
Old 05-26-2017, 06:14 PM
PapaBearYuma
Seems to me, since they're self-adjusting, that you can emulate the self-adjustment by manipulating the bracket. In your picture above, the bracket would rotate the teeth "upward". Therefore, rotating upward should tighten the brake shoes against the drums.
Alternatively, using a screwdriver or brake spoon to lift the bracket, allows you to loosen the brakes.
Old 05-26-2017, 06:27 PM
john jamieson's Avatar
john jamieson
john jamieson is online now
Check your backing plates where the shoes rub on them. Over time they can wear grooves into the plates that prevent the brakes from operating smoothly.
Old 05-26-2017, 06:43 PM
Filthy Beast's Avatar
Filthy Beast
Filthy Beast is offline
Left picture is left side of vehicle....right picture is right side of vehicle
Old 05-26-2017, 07:12 PM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Maybe some trucks are different, but if you watch how the sef-adjusters are supposed to work it should make sense what direction they turn. Those look like the adjuster lever comes up from the bottom - they may be different! This is why using the manual is important with brakes I suppose. In the smaller trucks, when you back up and apply the brake, if there happens to be a little clearance (wear) in the brake lining the cable pulls the adjuster lever up and over the star wheel slightly, and upon release of the brake the spring tension on it pulls it back down, engaging one of the the star wheel ****, to turn the wheel one click.
So when you're looking at the innards on an F100 say, drum removed, the star wheel always turns "down" or towards the pavement to tighten the brakes. Those look different. That's probably why the confusion online.
It's confusing to describe because adjustment is normally done from the other side, through backing plate access hole. Threads are different on each axle, but not the direction they are turned, if you think about it. Note that the design is usually so they will ratchet only one way, so that they will never loosen on their own. A screwdriver can be used to tighten the star wheel, but the adjuster lever has to be pushed out of the way with another tool in order to loosen on the typical adjuster.
Quick Reply: Seized Drum...
