door handle shaft repair- '56
Received 4,132 Likes
on
I did both of mine plus the window cranks with the instructions on Midfifty...very easy
http://midfifty.com/instructions.php?ID=53
on
Think you got the wrong one John. Instructions - Mid Fifty F-100 Parts
on
on
The instructions I posted just shows how it all goes together, I put the longer shafts on mine. Like they say you almost need three hands but once you get the first on done the second is much easier. You don't want to do it in a real cluttered shop because those springs can fly a pretty good distance...lol
on
on
Take your time and follow these instructions and all will be okay...
on
What I did was crank it as far as it would go and marked where the rivet was then cut a small corner off the gear where my finger is pointing.
cranking it all the way to the other end of the gear I marked and cut a small corner off again. It doesn't effect the operation of the window crank but allows access to install the bolts for the crank shaft installation.
Done finally
What a PITA these are but it's done. I ended up grinding about 3/4 of an inch out of each side of the fan gear-like 56panelford says- which allowed me access to the rivets for the gear box. Thank God I was at my buddy's shop with a welder so I could tack the shaft down. That also allowed me to use rivets to reattach the cover! Now, with good teeth on the shaft, I now have to buy all new handles because mine are wallowed out.
