Pre fill oil filter?
I see no need. Most of the gas burner engines use to have the oil filter mounted at an angle that would not allow you to pre-fill the filter. Never heard of any of the hipo engines such as the 427, boss 302 or boss 429 and similar CJ/SCJ engines ever have a problem by not trying to fill the filter during an oil change.
There should be enough oil film on the bearings and parts to prevent problems prior oil filter filling and pressure up to normal psi.
For me, filling the filter is just an opportunity to drop the filter or turn it on its side prior to installation and making a big mess....lol
I used to do it for my old truck, my 96 F250 after I put the dual filter setup on with the adapter plate on the 351w. I can't do it to my son's 99 Cherokee XJ as the filter sits horizontal on the motor, same as on the 22re's that my 88 and 94 4Runners came with. But when I have changed my wife's oil in the 09 Escape, I've prefilled the filter. Now, I've been taking it to a friend's shop. I take my new 16 to the dealer.
Received 6,868 Likes
on
But, to be concerned with trying to pour oil thru the check valve holes of the filter to make sure it gets filtered, is way way way over kill imo, unless you first filter the other 12 quarts before you pour it down the oil fill tube..?
jmo
