2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Airbags installation
Old 04-08-2017, 09:22 PM
EpicCowlick's Avatar
EpicCowlick
EpicCowlick is offline
I installed Air Lift's air spring and compressor system before heading out to with the 5th wheel. Installation was pretty straightforward. I also used an upfitter switch for the first time on the 2017. That was a piece of cake.
For any who are interested, here's the little project.
Old 04-08-2017, 09:30 PM
wb6anp's Avatar
wb6anp
wb6anp is offline
video not available, yet.
Old 04-08-2017, 09:39 PM
EpicCowlick
Sorry, did it again. It's public now.
Old 04-08-2017, 10:10 PM
wb6anp's Avatar
wb6anp
wb6anp is offline
Almost looks like enough room for a small tank above the spare also. I need to ask my dealer for a replacement lock in the bumper, mine has fallen out, I guess it wasnt locked when originally installed.
Old 04-08-2017, 10:14 PM
EpicCowlick
It would have to be a small tank to fit in between the spare tire and the bed. I haven't decided where to put the 2.5 gallon tank yet but now I know there's plenty of room for two more 100% duty cycle compressors.
Old 04-08-2017, 11:05 PM
MagicMtnDan's Avatar
MagicMtnDan
MagicMtnDan is offline
This is encouraging - I'd like to install an air tank for tire fills but I wonder how long it will take an onboard air system to fill up these tires (I'd like to air down for off roading and air back up from the onboard air system).
Old 04-08-2017, 11:18 PM
das_16's Avatar
das_16
das_16 is offline
good job on the video
Old 04-08-2017, 11:32 PM
kry226's Avatar
kry226
kry226 is offline
Nice. One thing I really like about the Ford is all of the apparent room under the bed, even on the short ones. With the others, it seems you need the LB to do anything under bed.
Old 04-09-2017, 04:36 AM
44Dan44's Avatar
44Dan44
44Dan44 is offline
Great video, thanks for all the unseen effort in the editing to make it all flow nicely.
Old 04-09-2017, 08:47 AM
scalemaster1's Avatar
scalemaster1
scalemaster1 is offline
thanks for the video .
Old 04-09-2017, 10:08 AM
DL222's Avatar
DL222
DL222 is offline
Great video thanks.
Are you planning on doing one for a fuel filter change?
Old 04-09-2017, 10:40 AM
347Flatty's Avatar
347Flatty
347Flatty is offline
Great job on the video! How has the airbags affected your ride quality when empty and the psi lowered?
Old 04-09-2017, 10:47 AM
wb6anp's Avatar
wb6anp
wb6anp is offline
Still considering air bags, just to level my trailer, I cant get a hitch adjusted to levle it properly, since it has torsion axles it is supposed to be as level as possible.
Old 04-09-2017, 12:13 PM
FishOnOne's Avatar
FishOnOne
FishOnOne is offline
Received 1,462 Likes on 904 Posts
First class video...
Old 04-09-2017, 12:29 PM
SD2's Avatar
SD2
SD2 is offline
Nice video. Thanks for sharing!
Quick Reply: Airbags installation
