New pads and rotors... Before I drop the cash double check my items
On a side note, Apoc, I would recommend getting these for your new brakes. They are sold in pairs, so buy two set.
Russell Speed Bleeders 639560 - Free Shipping on Orders Over $99 at Summit Racing
Truck and SUV Application Guide - Speed Bleeders - Russell Performance Products
I hope I'm not hijacking this thread, but I, too, am shopping for brake pads this morning. I recently bought a 2005 Excursion with 80k miles. The brake pads and rotors look absolutely brand new, and they SQUEAK badly. I mean they squeak LIKE CRAZY every single time I tap the brakes. They stop perfectly fine, but something has to be done.
My experience and the research I've done lead me to believe that the brakes were replaced, and didn't go back together just right. Either some shims were omitted or some "high performance" pads were used with a non-OEM composition, or both.
I think OEM or OEM-style pads with proper hardware should solve this with a minimum of expense and trouble. Here's what I would like opinions on:
1) With virgin-looking, stock-appearing rotors, should I leave them, machine them, or replace them?
2) Choose new pads (prices for both axles on RockAuto):
Motorcraft (Ford) OE $123.
Wagner OE-style $50.
Raybestos OE $36.
AC Delco $39.
Bosch $42.
Raybestos OE $36.
AC Delco $39.
Bosch $42.
They probably used metallic/semi metallic type, since you had trouble with noise, i would try oem, the other look like semi metallic
My truck had OEM pads and squealed like crazy on light brake applications. I had to get on them hard to not squeal. I found that when I washed the truck, they were quiet for a day. I tested that by spraying a hose into the wheel openings (on cold brakes of course) until the black brake residue quit coming out from there and they would be quiet for a day or so. Now that I have the Powerstop kit, I haven't heard a peep whether they are clean or dirty.
Raybestos OE $36.
AC Delco $39.
Bosch $42.
Raybestos OE $36.
AC Delco $39.
Bosch $42.
They are a upgraded rotor, not sure on the pad compound. But the calipers are a remanufactured unit. If you are upgrading consider the stainless lines aand speed bleeders during install.
I will say the weight of these trucks and Excursions are lacking in the factory braking setup. I went with the Hawk pads and Powerslot Cryo treated rotors. Next brake upgrade will be the Stainless lines.
#45
These powerstop kits. Are they getting installed because they are better than stock? Or are they getting installed to replace the worn out OEM stuff?
