How many miles are on your 5.0?
Old 10-23-2015, 11:29 AM
Mikes150's Avatar
Mikes150
Mikes150 is offline
I have had my 2012 f150 stx 4x4 for one year now and it has a total of 54503 miles. I love my truck! Just curious to see how many miles are on yours? I have heard many of these engines go at 100000 thousand miles. I have done all the maintenance recommended. I had a head replaced at 49000 miles.
Thanks!!
Old 10-23-2015, 12:00 PM
dh_meyer's Avatar
dh_meyer
dh_meyer is offline
My 2012 (5.0) is at 51,000. No known issues
Old 10-23-2015, 12:20 PM
TravisV's Avatar
TravisV
TravisV is offline
2012 5.0 66,xxx no real issues except for the quick connect on the rad hose from the bottle starting to leak..... just got back from picking one up at ford. $30 going to install today.
Old 10-23-2015, 12:54 PM
SBV45's Avatar
SBV45
SBV45 is offline
2013 owned for more than a year. Bought it with 2200 mi. Now have 14,000 (barely broken in). No problems.
Old 10-23-2015, 01:58 PM
David W Jones's Avatar
David W Jones
David W Jones is offline
2012 2wd 157" WB Super Crew Lariat bought new right after Christmas 2012. It'll turn 70,000 miles on the way home this evening. 1st oil change at 5000 miles and since then I've used 10,000 miles as my oil change interval. Mobil1 full synthetic in 5w-20 only. It uses very little, if any, oil between those 10,000 mile oil changes. Still running the original Michelins and I estimate they'll go to 90,000 miles or so. Fuel mileage has averaged just over 19mpg for those 70,000 miles. I had one warranty repair on the truck where they added the miracle "blue grease" to the drive shaft to cure a slight bump as the truck left a stop. I've changed the air filter twice, installed new wiper blades once and poured a gallon or two of windshield washer fluid in.
Nothing else.
Old 10-23-2015, 02:37 PM
Scum Frg's Avatar
Scum Frg
Scum Frg is offline
2013 with 76,000 kms / 47225 miles.
Old 10-23-2015, 06:21 PM
BrassMonkey's Avatar
BrassMonkey
BrassMonkey is offline
I've got a 2013 XLT, only about ~17,000km.
Old 10-23-2015, 07:29 PM
eriebasin's Avatar
eriebasin
eriebasin is offline
Approximately 26,700 mi; still a adolescent, i know. First oil change at 5,000. I use Royal Purple full synthetic oil. I use the Intelligent Oil Monitoring system to tell me when to change it. I usually get about 8500, but change it at about 10% (I tow quite a bit but only drive 2.8 mi to work each way; both cause the computer to recommend a change short of 10,000 mi). It uses no oil; the level is always at the same spot on the dipstick. No issues.
Old 10-24-2015, 04:03 PM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
My 2011 had 134k with normal maintenance and chain tensioner replacement. My 2012 is currently awaiting a full engine after it broke a timing chain. I think for reliability I would expect these to be in line with their older modular counterparts and service life is between 175k and 300k.
Old 10-24-2015, 06:13 PM
maytag906's Avatar
maytag906
maytag906 is offline
2011 XLT 5.0, with about 38,000 miles. No problems.
Old 10-25-2015, 09:39 PM
paredneck33's Avatar
paredneck33
paredneck33 is offline
2011 XLT s/cab 4x4 5.0. Sitting at just over 61,000 miles. Changed air filter, spark plugs, and had the TCM re-flash update performed shortly after I purchased the truck due to the has shifting from 1 to 2.
Old 10-26-2015, 01:28 PM
aitg's Avatar
aitg
aitg is offline
2011 Scab XLT 4x4. Bought new 9/30/11. It now has 88,500 mi. on it with zero engine issues. I changed the oil and filter at 2500 miles. Since then, I go by the oil life monitor. I change it just short of 10,000 miles. Kendall GT-1 semi synthetic 5W-20, Motorcraft filters. It usually needs a quart at about 7,000 miles after changing.
Great engine, great truck.
Old 10-27-2015, 09:30 AM
Robbgt's Avatar
Robbgt
Robbgt is offline
2013 5.0. 31k miles. I've change the oil every 5k with motorcraft oil and filters and did tire rotations at the same time. Changed the air filter at 25k.
Now for the "fun" stuff: have had to had the rotors turned twice, the molded lead-frame replaced in the transmission for high gear engagement from a stop, the rear pinion seal replaced from leaking and TSB for rear end click when shifting to drive. The engine has also developed the dreaded "phantom tick".
As a note, my truck does not see a hard life. It is my personal truck and has only seen a trailer once and mostly highway use. Will probably drive it until right before my power train warranty runs out and trade it in or sell it. I've been a diehard Ford fan all my life however, I have been disappointed with the quality of this truck. Perhaps I just got a lemon...
Can you elaborate on what the problem was and why a cylinder head was replaced? Having a head replaced isn't exactly a "normal" thing...
Old 10-27-2015, 09:36 AM
blueovelboy's Avatar
blueovelboy
blueovelboy is offline
are shop 2011 5.0 has 188k on her and once it was in shop don't remember why?
my 2012 has 37k and no problems on it.
Old 10-28-2015, 09:17 PM
Rod Fletcher's Avatar
Rod Fletcher
Rod Fletcher is offline
'13 STX 5.0 4x4 126" WB, just about to hit 17k. Bought it Memorial Day weekend 2014. Oil change after first 1k, again at 5k with Motorcraft 5w20 blend, and at 10k & 15k used Mobil1 0W-20. Very random & infrequent clunk when shifting from P to R or between R and D. Only other issue I had was a taglight bulb socket that leaked water & corroded. Fixed the socket under warranty without issue, and neither I nor the tech could reproduce the clunk during my visit to the dealer.
I probably beat the hell out of it. I hold it on the floorboard through the top of 2nd gear at least once a day, usually more. And up until a month ago when my commute changed, it would see 100mph ~3 times a week.
Quick Reply: How many miles are on your 5.0?
