Top speed for 6.2 F250?
I was telling my wife we had a new reason to want to visit Moab now that Utah has some 80mph speed limits. But since we would go with the F250 it would be pointless.
This got me wondering... What is the speed limit. I searched and could only find people with raptors hitting the 100mph limiter.
I don't think I would ever want to drive the F250 past 75 but I wonder.
How fast can it go?
At what speed does it become worrying to drive? I assume it does not stay planted like a sportscar would at higher speeds.
How fast can it go?
The governor used to be around 96mph don't know if Ford changed it. My 04' has been well over 100mph for fairly short amounts of time and was rock solid. Not a speed I would want to sustain for long periods of time.
If you are towing a trailer I recommend just saying no to sustained 80mph. The ST trailer tires are rated for 65mph. They will handle more but I have noticed that weight, speed and heat can cause a lot of trucks along the side of the road with flats.
Just last night with an empty car trailer and I had a hard time staying under 80. These trucks just do it so effortlessly. This only applies when the road is fairly smooth, when on a rough road my plow package front springs really upset the rides and the truck wants to move around. The truck is a V10 and run a 5 star 93 octane tune, your results may vary.
top speed
Had my 250 to 94. I'll never try it again! Truck felt very light on it's tires, as if they were loosing contact with the road.I don't think it would take much to send it out of control.It's not so much that the truck can't make a higher speed but the tires won't hold together at sustained high speed.Hence the limiter.
do you have proper air pressure in your tires? are they stock or aftermarket? If you have some crazy big tires with a lift kit or something it may not be a good idea to go that fast but with the stock ones properly inflated the truck is very solid and you cant even tell you are going that fast unless you look.
