Ford Truck Parts for Sale Ford Truck related Parts and Accessories for sale
Parts Search
Keyword:
Category:
Price:
Private or Vendor Listing:
Location (State/Prov):
Item Condition:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Color:
Private or Dealer Listing:
Location (State):
Misc. 1973-1996 F-series and Bronco parts.
Old 07-19-2011, 05:15 PM
Fordzilla80's Avatar
Fordzilla80
Fordzilla80 is offline
Category: Interior
Price: $0
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): Prelude, Fit, S2000
Item Condition: FL
Shipping Information: Item can be shipped
Engine: Part suitable for gas truck, Part suitable for diesel truck
Hello, I am selling miscellaneous items from 1973-1996 F-series trucks and Broncos. All items are used and therefore are not perfect. I will try my best to detail the flaws each item has. I am selling everything as-is. If you have any questions about fitment or need further dimensions, please feel free to PM me. Thank you for checking out my listing.
1992-1996 F-Series and Bronco driver's side door panel. Has some wear in the area around the armrest that may or may not come off with some good degreaser. You will need to provide your own clips as well as window felts. $10 plus shipping.
1980-1986 Custom door panel armrests. Made these in my high school shop class. The holes are already pre-drilled, however you will need to provide your own screws to attach them. $10 plus shipping
1980-1986 door panel chrome trim. A few of the tabs have broken off, but it does not seem to affect how the trim is held on the panel. $20 plus shipping.
1980-1996 aluminum scuff plates. One has two extra holes drilled in it. Scuff plates will be cleaned up before they are shipped out. $10 plus shipping
1973-1977 Bumper Guards. May fit other years and models. $20 plus shipping.
1980-1986 F-series and Bronco gauge cluster. Custom painted white with blue numbers. Silver backing. 89,000 miles. If I recall correctly, the shift indicator cable housing is broken. Not 100% sure however. $20 plus shipping.
1987-1991 A-Pillar Trim. Came from a Bronco, may fit F-Series. Looks like they may have originally been gray, but were painted black. As you can see, the top section of the passenger side trim piece is cracked, however I do not believe it affects the trim piece in any way. $10 plus shipping.
1980-1986 Aluminum body side moldings. These came off of my 1980 F100 long bed. Pictured are the pieces from the fenders, doors, back of cab, and the driver's side rear bed molding. I also have the moldings that go in front of the rear wheel wells for a long bed, but they are still on my F100. Will be removed before they are sold. I do not have the molding for the passenger side rear of the bed. I also do not have the wheel arch moldings. All the moldings have at least one or two dents or scratches with the door trim having the most issues. $20 plus shipping
1980-1996 F-series and Bronco, 1983-2011 Ranger dome light base, and two covers. These may fit other models as well. $5 each plus shipping. I will throw the base in free to whoever wants it.
1980-1993? Cargo Light housings. They are arranged in order of best to worst, with the best housing being in front. The rear housing has a crack down the center of the lens that has been glued back together. It has held for over a year, so I believe it will be okay. I only have one gasket, and that is what is pictured. All housings will come with the screws. $5 each plus shipping.
1980-1996 Dome/Map lights. The one on the left is designed for Broncos, Super Cabs, and Crew Cabs, while the two on the right are for Single Cabs. The one on the left is missing the bulb socket, but I believe it is easily added. You will need to furnish your own dome light bulbs. The map lights still have the bulbs, however I can not guarantee their proper operation. These lights will interchange, however the map lights will be pointed in the wrong direction. $10 each plus shipping.
1983-1986 Clock. I can not quite remember, but there may be a difference between the wiring of the 83-84 and 85-86 clocks, so be advised that this clock is from a 1985. This clock does not work, and will need to be fixed by someone who knows about electronics. When I tested it, all the connections get power, even inside on the circuit board, so it may be as simple as a capacitor or something like that. $5 plus shipping.
1985-1986 Ford Electronic Radio with Cassette. This radio came from the same truck as the above clock, and does not work either. Just like the clock, it seems to have power everywhere. Good for parts or someone who knows about electronics. $20 plus shipping.
1980-1986 "Sport" mirrors. May fit more years and models than listed. The mirrors are in fair shape overall. The glass is perfect, however the outside chrome is bubbling and will need to be stripped. Can send pics to show damage if requested. The mirrors also suffer from the usual loose ball mount and do like to move out of position when bumped.$20 plus shipping.
1980-1986 sun visor. I believe the color is called "Saddle". $5 plus shipping.
1980 Chrome/Black trim molding. This piece is for the passenger side, in front of the rear wheel well. Will fit 81-86, however the black vinyl insert is larger than the inserts on the 81-86 trucks, so it may stick out more. $5 plus shipping.
1980-1991 vent window rubber. Will try to cross-reference the vent windows in F600's and see which year this would best fit. $5 plus shipping.
1980-1996 Trim Rings. These came factory with the argent colored 8 spokes commonly found on 1985-1991 F-Series trucks and Broncos, but may fit other wheels as well. These trim rings are missing the factory red pin-stripes, but those can be easily added by a steady hand. $10 each plus shipping.
1980-1996 Center Caps 1st set. Will be cleaned before they are shipped. These caps have common road wear such as scratches and pitting on the back side of the caps, however they still look great when they're shined up. $30 plus shipping.
1980-1996 Center Caps. 2nd set. These will also be cleaned to a shining finish before they are shipped. These have minor pitting on the chrome outside sections, but still look good. One of the caps has some weird streaks in the chrome that I cannot seem to remove. Looks like oil on a driveway after it rains. The two on the bottom right are missing their center emblems, however those can be found in the LMC and NPD catalogs. Or if desired you can cut the lip out and make them clear 4x4 hubs. $20 plus shipping for the set with center emblems, $10 plus shipping for the two without center emblems.
1980-1996 Center Caps for 4x4 front hubs. $10 plus shipping.
1980-1996 Passenger Side Black Seat Pivot Arm covers. To be used on 80-86 trucks, a hole will need to be drilled in the seat pivot arm. $5 plus shipping.
1980-1986 Cruise Control Horn Pad Parts. These two items came from an Econoline, however they should fit on F-Series and Broncos as well. I do not have the burlwood face for the horn pad. $5 plus shipping for the harness and/or the backing.
1980-1986, Maybe 1987-1996 Door to Cab speaker and power options wiring protective boots. $5 plus shipping.
1980-1986 Battery Hold Down Support. Bolts to the radiator support. $5 plus shipping.
1980-1984 Gas Cap. May fit 1985-1986 non-EFI trucks. $5 plus shipping.
1980-1986 Misc Switches. Headlight Switch, Non-Intermittent Wiper Switch, Dual Fuel Tank Switch, and Heater Output Switch for non-A/C trucks. $5 each including shipping. Pics upon request.
1980-1996 Exterior Door Handles. Both have some pitting and would need to be re-chromed or painted. Good for custom applications where body color handles are wanted. $10 plus shipping.
1980-1986 Interior Door Pull Mechanism. Will update when I find out which side this is for. $5 plus shipping.
1980-1991 Antenna Base with Cable. No Mast. Cable end that plugs into base may need to be addressed. $10 plus shipping.
Old 07-25-2011, 12:32 PM
Fordzilla80
Feel free to make an offer on this stuff guys. It'll be much better on y'alls trucks than in my shop.
Old 10-07-2012, 07:15 PM
phayzer5's Avatar
phayzer5
phayzer5 is offline
I realize you posted these last year, but do you still have those bumper guards available? I'm up in Gville but have family in Dunnellon area that I visit
Old 10-07-2012, 10:47 PM
Fordzilla80
Unfortunately those are already gone. Good luck on your search!
For anybody else who sees this thread, here's a list of what I still have. If it isn't listed, it has already been sold.
  • 1980 chrome/black trim molding
  • Battery hold down support
  • Wheel trim rings
  • Center caps
  • Aluminum Trim Moldings
  • Base Dome Light and extra lens
  • Digital Clock for 83-86 trucks.
Raleigh1
1978 - 1996 Big Bronco
682
03-18-2016 01:29 PM
DaXman
07-03-2015 05:38 PM
JoePhoto
40
12-03-2013 01:28 PM
ctubutis
11-15-2013 10:25 AM
Fordzilla80
11-22-2012 08:28 PM
Quick Reply: Misc. 1973-1996 F-series and Bronco parts.
