Project Dentside Diesel
Old Oct 16, 2010 | 11:49 AM
"Top Fuel" Bender's Avatar
"Top Fuel" Bender
I've always loved my Dentside Fords, taken home from the hospital in my dad's '77 F-150,
1st vehicle was a '79 F-250, ect.... but never cared for the carb's or motors for that fact.
Got married , wife's grandfather had a few cummins truck
picked up a '92 12v o.d. auto LE extended cab 2wd 3/4 ton when he ran it off the road a few years back
90,000+ miles later still loving the torque and reliability
Jan 1st a drunk hit the front of my cummins
2 weeks later a friend of my called and asked if I wanted his '78 F-250
(I've managed to track down and pry every last ford out of all my friends trucks over the years)
Got the insurance check, cashed it and headed up to grab the truck
Dawned on me to combine what I've got to get what I really wanted out of a truck
The great style of the Ford and the power/economy/reliability of the cummins
So here we go
Starting disassembling the Dodge (let me know if anyone needs anything)
and going into this
For now it's going to be a function over form build
need to get both trucks apart and one back and running before winter
I've got an unheated garage but it's pretty well packed soooo
Looking to put the 12v 518 into the Ford on the Ford NP205 T-case
Get it up and running work the bugs out over winter and do the pretty stuff in the spring
Still miss my 2nd truck
15" lift and 44's , not bad for a 17 year old
So tell me I didn't just do something stupid tearing apart one and ready for 2 good running trucks
"Top Fuel" Bender
Got some new toys
Advance Adapters nv-4500 to ford np 205 kit
Very nice kit ! was going to make my own but figured I have enough to do for now
Gotta love that beefy spud shaft
notch in the rear of the tailhousing to clear the t-case shift forks
mock-up to np205 t-case to check fitment
needed to trim almost .200" off so I cut the shaft down .250" for good clearance
all better now
Old Oct 16, 2010 | 11:56 AM
"Top Fuel" Bender
Hughes Diesel Converter is here
Trans is all done
A-518 Auto , full Trans-Go kit, low pitch gear set, 5 gear steel planetary gears , deep pan, large steel servo, higher ratio kick down arm
Old Oct 16, 2010 | 02:51 PM
nevrenufhp's Avatar
nevrenufhp
Looks like a great start to a fun ride.
Old Oct 17, 2010 | 01:45 PM
06silvercrew's Avatar
06silvercrew
Great project. Keep the pics coming!!!
Old Oct 17, 2010 | 03:25 PM
"Top Fuel" Bender
thanks guys
Old Oct 17, 2010 | 03:40 PM
impalaslayer's Avatar
impalaslayer
sweet man, i picked up a zf5 yesterday to mate to a 12v when i find one. going in my hiboy!
cant wait to see this progess
Old Oct 22, 2010 | 06:24 AM
torkum's Avatar
torkum
Awesome project, keep the pics coming
Old Nov 16, 2010 | 05:36 PM
crazyredneckanyhow's Avatar
crazyredneckanyhow
I got the same setup from advance adpt and its nice. How did it set you ase compared to stock? Is it flat or tilted up a little?
Old Dec 12, 2010 | 12:29 PM
"Top Fuel" Bender
Sorry haven't been on in awhile
tilted up a few degrees , little over the dia. of one bolts
Here's a pic of new motor mounts
Got them from a dragracing buddy of mine of @ Welcome to Poly Bushings.com
Look pretty stout, should do the trick
these are from his 2nd batch
He thought the 1st were a little harsh
Got some other bushings misc. use...
Old Dec 12, 2010 | 12:46 PM
"Top Fuel" Bender
Took a break to finish up some stuff on the garage
I've been running an extension cord out for a few year and figured it's do time
Picked up a used 200amp panel, meter base and weather head from a jobsite teardown
So I only had less then $100 in wire/clamps/ground rods
I thought that having lights on a switch was cool till I fired up the air compressor !!!
80 gallon 5hp 2-stage snap-on compressor I traded for some repair work at a garage
It's got some hours on it but for home use it'll work great
Finally getting my nuts and bolts racks all organized (looks like I'll never need to buy zip ties or hoses clamps again, man I've got them laying everywhere)
Pays to clean up the garage every once in awhile
all this in time to find out I've got no work at work (machine shop), so if anyone needs anything let me know
Old Dec 21, 2010 | 01:35 AM
jfive's Avatar
jfive
So here we go
and going into this
To bad you aren't close, cause I would love to have the back half of the truck to make a box trailer out of. Nice looking truck for that engine though.
Old Dec 22, 2010 | 03:58 PM
73FordF100's Avatar
73FordF100
This is a great thread !!! The damage on the Dodge doesn't look so bad, but it's good you are putting the Cummins in something that looks a whole lot better than that ugly Dodge IMO lol. You are the first one I've ever seen doing a Cummins swap and using an automatic transmission.
Old Dec 22, 2010 | 07:49 PM
"Top Fuel" Bender
Yeah , the busted Dodge was a good excuse for talking myself into doing it
Truck ran too good to take apart but ...
Need my dentside back and a 4x4
Old Dec 22, 2010 | 08:08 PM
jfive's Avatar
jfive
I know your too far away for me to asks for the leftovers of the dodge, but you should make a truck trailer out of it for yourself. That style dodge truck is one of the most heavy duty trucks there was, which sucks to drive, but makes it great for holding weight. It should hold about 5000lbs with good tires.
gsb15
Engine Swaps
19
Feb 8, 2019 09:55 PM
Aaron-71
237
Jan 24, 2018 08:32 AM
Aaron-71
123
Jul 7, 2015 05:37 PM
carbongs
49
Apr 2, 2011 09:28 PM
