So I recently was able to find 2 more 8 lug innies. I had them powder coated about a month ago and just his morning I had new tires mounted. I love the look. The tires are 235/85/16 Firestone Transforce HT. Drives and steers a lot better than before with the 245/75/16 tires.
-Patrick
No, I haven't been able to locate a set. The ones for the 16" wheels are pretty darn rare. I kinda like the look without the caps, being able to see the rear axle caps... it's a work truck. F250.
Looks nice! It's amazing how good an old truck with decent paint can look when the wheels, tires and bumpers are in good shape.
These are C7TZ-1130-G the 15" outie hubcaps used on 1967/72 F100's. All 4 wheels on 2WD's, rear wheels only on 4WD's.
1967/77 F250/350's used different hubcaps, could be painted or stainless steel. 1967/69 F250/350 could be innies or outies, 1970/77 F250/350 are outies.
1969/74 E300 & 1975/77 E250/350 used the same outie hubcaps as 1967/77 F250/350.
PWM TRUCK, the color looks spot on for Wimbledon White. Do you know what brand and color code they used on your wheels? Also, where did you have them coated? There are only a few places locally that do powder coating, and they don't have many colors to choose from, but if I supplied the powder they would take care of the rest.
Thanks
Hey there 66v8baby, I took Fords and Whalers advice from this post and went with the code that he used. My local Powder Coating place here in Portland, Oregon is called Color F/X and they are great. Affordable too. Media blasted and painted the wheels for $65 each. Hard to beat.
Here is the other post, some disagreement on what color the wheels may have originally came,but I wanted mine to be WW.
Cheers!
Not the best condition. Two are decent. One is dented pretty good. One has a hole drilled in the center of it. 40 + shipping. PayPal.
Hey there,I just want to verify that these are for the 16" wheels found on F250s, as they are larger in diameter and deeper than the caps for the F100s.
Thanks.
Thanks.
These came off my 65 3/4 ton. Numbers Dummy will know better than I if they will fit your wheels.
Yeah, those are correct. ~8-3/4" opening on the back.
For $40+shipping I will take them.
You can email me at pwm70@comcast.net or send me a private message on how to get you the funds. My zip is 97213 to estimate shipping cost.
Thanks, Patrick
