clifford is getting there now.
#2986
Yeah, the old OX is just a puller. Every time I back into this darn wooded driveway here in the UP I scratch the OX up some more. Oh well, just some more battle scares, lol.
First time in ten years I have internet up here. Finally found a spot to shoot thru the trees and get online! When I pull out of here I'll stop and carefully mark the spot where the tires are so next time I'll be online, unless the trees grow up in this spot.
#2987
#2989
#2991
#2992
No heat :-( I went cheap lol. Signals yes but the marker and signal are together. I'm going to separate the two so I can get my little trucker light thing going on. I have been working on him . I got a ton of suspension and frame parts clean so hopefully they will get painted and hung soon. I'm at an impass tho on the cab at the moment. I was going to go cheap on underside paint. I have reconsidered and am saving up for good correct color automotive paint. I can't stand the thought of cheap paint peeling down the line and getting to do this over. Hopefully I will get the drivers mirror hung soon. The frame should come together fairly quickly then I suppose its axle time.
#2994
I sure hope.
Fuel lines,pump,switcher valve cleaned and installed.
Heat shields all shiney and clean n stuff
Lots of cleaning done and yet more plus sanding and painting to come.
Starred cleaning bolts and steering box clean.
Hopefully tomorrow some things will get painted . Im bummed i didnt get to the paint store to get the reducer for the black single stage im going to do most of the small parts in. Guess if i get everyrhing sanded and ready for paint monday ill get that done.
#2996
#2997
#3000
