47 rear wheel diagram
Old 07-01-2017, 03:48 PM
Reddog7's Avatar
Reddog7
Reddog7 is offline
Does anybody have a diagram for a 1947 1/2 pickup rear wheel assembly. I am putting the bearings, seals, washers, and nuts back on and I want to make sure I get it in the right order. It has been a while. Thanks
Old 07-01-2017, 06:30 PM
Rust Wrangler's Avatar
Rust Wrangler
Rust Wrangler is offline
I found this at Van Pelt. Hope it helps.
http://www.vanpeltsales.com/FH_web/F...2to47truck.jpg
Old 07-01-2017, 06:51 PM
GB SISSON's Avatar
GB SISSON
GB SISSON is offline
Thanks, It's helping me too!
Old 07-01-2017, 06:52 PM
tacomacream's Avatar
tacomacream
tacomacream is offline
Old 07-01-2017, 09:16 PM
Reddog7's Avatar
Reddog7
Reddog7 is offline
Thanks, just what I was looking for. This really helps.
Old 07-01-2017, 09:17 PM
GB SISSON's Avatar
GB SISSON
Good info Mike. I was thinking the roller bearing was lubricated by the 90 wt from the rear axle. I have my brakes completed and bled but the drums are just on temporary as my new seals came in last night. I'll pack the bearings and install the new seals after the holiday weekend. I have read that it is really important to tighten the big nut to proper torque value as it's the taper that should transmit the torque of the engine to the road. The axle's key is not up to that task. Never mind losing a wheel/drum assembly on the road.
Old 07-01-2017, 10:55 PM
Rust Wrangler
Found this on axle nut torque procedure. Hope it helps.
The 'V8 Times', Sept/Oct 98 Issue, pages 46 and 48, quotes several Ford Service Letters and later corrections.
The final direction on tightening axle nuts reads: "tighten nut 356074-S to 200 to 220 foot pounds; then continue tightening to the next castellation providing final resultant torque does not exceed 275 foot pounds.
usuallybowtie
07-15-2015 12:09 PM
Jake in PA
03-26-2013 07:34 PM
6fifty_f1fifty
10-23-2010 10:04 AM
mando jake
01-12-2009 04:59 PM
Okie f Muskogee
Aerostar
04-03-2005 12:11 AM
Quick Reply: 47 rear wheel diagram
