Oil Cooler Bypass Valve and Temperatures Differences
#91
Looks like I'm a little late to this party.
For what it's worth, I put a new oil cooler in my truck a few years back. When I assembled everything, I misplaced the bypass valve and left it out. My temp spreads at 65mph were 12°.
I ended up finding the valve and installing it at my next oil change and my temp spread changed to 6° at 65mph.
#97
#98
I just ordered the parts from Bulletproof and they should arrive at the end of next week. It could be a shot in the dark, but with the truck performing with no issues besides the 30* delta differences. Hopefully this will fix the problem, if not, I know where the issue lays.
#100
#101
My truck is very similar to Copper.Farms. Driving level @ 65 my dp is around 5 degrees. If I'm towing my 11k fiver my dp drops to 1. But if I have to pull a steep grade my ect and eot will continue to rise until the fan fully engages at 225. Then the ect will drop back to around 200,while the eot will take a lot longer to come back down. So do you think the bypass valve could be partially stuck open all the time?. That could explain the temperature dp while unloaded. Then when loaded, the oil flow increases due to the rpm increase. Which moves more oil through the cooler.
I'm going to have to pull that valve now and check it out.
#102
RPM equates to volume for both LPOP and HPOP.
IPR/IPS increases with load on motor.
Eventually the motor reaches a tipping point in which the oil flow shifts from being pushed to being pulled - we would not notice until the LPOP drops below 7psi, though the wear on the valve indicates that the valve is very active.
I would extend further, by saying that the oil cooler bypass valve is probably more active/worn in a manual transmission than in an automatic - in that the constant motor load/unload of manually shifting up through the gears reaches that tipping point multiple times where as an automatic is more constant load at constant rpm to obtain acceleration through the transmission rather than the motor.
Obviously nothing can help a clogged oil cooler other than replacement.
#104
#105
