F100 Crown Vic 460 Viking Build
#408
#409
We replaced a few things on the CV. It was in great shape so not everything needed to be replaced.
#412
#413
#414
Steering.
Fully extended the Borgeson shaft and cut down to 16.25.
Rocknthehawk lead the way for the Borgeson parts on his build:
https://www.ford-trucks.com/forums/1...-vic-swap.html
Borgeson part numbers on Summit:
013452
014955
450024
013452
014955
450024
#415
Looks good, at least you can route your headers around it. Normally you need a third u-joint and bearing support to clear headers.
I usually use a vibration dampener u-joint in place of a rag joint(right at the steering column.) Maybe its just over kill. I'd be interested in knowing if I'm just wasting money on a more expensive u-joint. lol
#416
Gauge Cluster Refurbish.
Junkyard Econoline supplied gauges and instrument panel backing. Red needle paint from White Face Gauges - Custom Gauges - Your Auto Gauge Specialist
LEDs from yitamotor on eBay. Ships out of WA. The LEDs in the pic are
https://www.ebay.com/ulk/itm/261283749831
Before and after red needle paint. NOS 100mph speedo. Did not paint the speedo. All bulbs are LED.
#419
#420
Thanks man. Wheel and tire combo? Nothing is set in stone. 16s or 17s for wheels. Skinny up front and extra wide in the rear for tires. Going for an aggressive look.
