Partial Answer
[Ouote] question but did the 4407 come with and without the pto option [.Ouote]
http://kingomatic.com/documents/WebT...ansferCase.pdf |
Thank you DRRXR for the reference chart. The only odd thing with it is there is nother listed for 95 and older F350.
The guy I bought the first one through says he just pulled three others and, from auto and standard trans, and say they all look like the one he sent. I emailed him back to make sure they were 96-97 and if the tags were on them to see if they said 4407. Not sure if this makes a difference or not but my truck has the heavier weight rated ttp 50. |
Jim
I cant find squat either on a pre 96 Still lookin though |
Wouldn't surprise me if ford threw some odd ball T case into my truck. Is there a place that would say what the output shaft diameter should be? Or if the same for the 250/350? Very perplexing.:confused:
food for thought
Originally Posted by wildstang
(Post 9323598)
https://www.ford-trucks.com/forums/8...the-water.html Even more http://www.powerstrokenation.com/for...3996&showall=1 |
Funny, sounds like my situation, well not really funny.
I was looking at this a couple days ago.
4407F was used in the 250 and 350, but only behind the E4OD and only in 96 and 97. Yokes seem to be impossible to get. |
1 Attachment(s)
I just got a 1356 BW for free!! Also a ZF5 4x4 tranny...
the BW has a slip in rear yoke, but on that yoke, the drive shaft bolts to... Attachment 203498 That yoke slides in and out and the drive shaft bolts to it.... |
Mustangmat. They are talking about the front drive shaft/ yolk
Originally Posted by Diesel_Brad
(Post 9327189)
Can you tell what it is? |
That chart linked above is not totally acurate. I had a '95 F-350 with a 1356.
Matt, it's a 1356, slip in rear yoke. |
Ford seems inconsistent also. They just pull whatever fits that they have in the bin.
Kinda resurrecting a dead horse here. But just some more info for anyone needing it. My 97 was auto with 4407 tcase, no slip yoke front or rear, and I swaped to a hand shaker last year. The two went together without a hitch, and I've been beatin the crap outta it since.
