How good is the Dana 24 transfer case?
I have a 68 F-250 hiboy, and its built to the hilt, but the transfer case is slipping out of 2high, into neutral,often.I was quoted a price of 185$ to have it rebuilt, is it worth it, or should I adapt a NP205?
The transfer case is a divorced unit, and it has been a blessing in dealing with driveline angles, with my lift.With the body lift, shackle lift and suspension lift, I have 14" of lift.Is it a trans case worth rebuilding or should I scrap it?Any help would be appreciated. |
If you have a chance to upgrade,you will have the case out anyway,go to the 205, it's a bullet proof box especially if you run a lot of horses.I went from the single speed to the 205 and have not had a hint of trouble in 5 years!!
"bowties in the rearview mirror" |
I have to agree with the previous post. My buddies and I's NP205's have takend all the off-road abuse that we can dish out, and thats with built engines. You won't regret a swap.
I would pay the 185. I have 1972 f-250 with 390,60front,14bolt,lockers,etc. Am still using Dana 24,after almost 30 years I have never had a problem.
so is the dana 24 larger than the 20 and 21. must really scream in low range with the straight cut gears. if anyone wants i can scan the disassembly/reassembly instructions and post them on photopoint.
Inf
Originally Posted by mj
(Post 502475)
Originally Posted by VanKleeck
(Post 19863391)
I would like this information if at all possible, picking up a dana 24 this weekend and it needs rebuilt
Originally Posted by ford390gashog
(Post 19863410)
This thread is 21 years old.
and he has not posted in 20 years. |
nevermind, i screwed up!!
Originally Posted by tjc transport
(Post 19867080)
actually, it is only 20 years old.
:-X22
i did not look at his last log on, just the person questioned, MJ |
