Manual steering box lube question
What lubricant is used in the manual steering box , I'm going to check Mine on the '59, and need to know what to use
Here's all the info you ever wanted for that subject. https://www.ford-trucks.com/forums/8...ml#post7320288
Shop Manual calls for SAE90 Gear lube!
Thanks guys!!
I went with the grease in mine as I heard to many stories of leaky boxes after filling them with oil. I believe I drilled out one of the plugs and intalled a zerk, then kept pumping untill it came out of the other plug. The thing has worked great for several years so far.
