I'm looking for a 4WD AOD output shaft, preferably a 4 hole. I have a 86 Bronco 302 AOD that need rebuilding and I have a 89 2WD AOD I was going to use but would like to build it and just swap it out. It seems like 4WD shafts are as rare as hen's teeth.
that's larry if he fails to have a item, it's very highly he knows who may, and freely passes the info along .
glad you were able to find the needed item good luck with the rb
