Complete running truck for parts
For Sale1999 Ford F-350 Super Duty
Price
$4,500• OBO
- Location Evansville, IN, 47720, USA
- Condition Used
- VIN 1FTWW33F3XED19674
- Mileage 207,600
- Engine 8 cyl
- Drive Type 4WD
- Transmission Automatic
- Vehicle Type Truck
- Exterior Color Black
Description:
I have a good running truck but it's at the end of it's service life. 7.3 DI turbo, automatic and 4X4. It fires right up and runs good. It has the 154 inch wheel base so you need 40 acres to turn around but it drives okay. The body is fairly good and the cab mounts seem decent. It's a northern truck that came down here (S.W. Indiana) and was used as a snow plow. The frame has rust. Mostly not too bad, but ugly.
THE FRONT SECTION ON BOTH SIDES HAS HEAVY PERFORATION!
While it runs and drives, if you hit something it will probably fold up. I have added some bracing to make it a better driver but I'm selling it as a rolling parts supply. I've had two welders offer to repair the frame. One by bracing and the other by clipping and splicing part of another frame he happens to have. I bought the truck to do some projects and it did just fine. I'm old and retired and don't want to fool with the truck.
4 doors with a 9 foot flat bed. The hoist operates but the pivot pin sheared from rust. Heat works and a/c holds pressure. I never bothered to get it working. It does have some rocker rust along with some on the cab corners but I've seen a lot worse. The frame is the main issue.
If you have a roll over, this will build you a nice truck. The same goes if you have a good, bare frame. I considered pulling the drive line and front axle to sell and cut the frame to make the rear into a 1 ton dump trailer. Again, I'm old and don't feel like it.
I have a clean and clear Indiana title in my name. Located in extreme S.W. Indiana. You can contact me here via PM or by email at yanktanks@aol.com I've got a full driveway so I'm not particularly looking for trades, but will consider interesting ones.
