For Sale: 1979 Ford F100 Ranger XLT
For Sale
1979 Ford F-100
  • 1979 Ford F-100 - For Sale: 1979 Ford F100 Ranger XLT - Used - VIN F10GNED7581 - 158,432 Miles - 8 cyl - 2WD - Automatic - Truck - Black - Raleigh, NC 27612, United States
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
  • Price
    $12,000
    • OBO
  • Location Raleigh, NC, 27612, USA
  • Condition Used
  • VIN F10GNED7581
  • Mileage 158,432
  • Engine 8 cyl
  • Drive Type 2WD
  • Transmission Automatic
  • Vehicle Type Truck
  • Exterior Color Black
Description:
Description: 302 V8, 2 wheel drive, short bed, C4 automatic transmission, power steering, power brakes, factory air conditioning*. Silver and black color. Actual mileage 158432.
 Reason for sale: I’ve had the truck since 1996. I’m downsizing my vehicle ownership.
 Condition: body in good condition, mostly original paint, no rust. Frame in good condition slight surface rust. Matching VIN codes on body and frame. Interior in good condition. Original Ford stereo radio repaired and reinstalled. Engine cylinder compression all in 140/150 range. Clear North Carolina title.
* AC started freezing over when running it for a while, about 15 years ago, so I stopped using it.
 Recent:
>Replaced front rotors/hubs, new inner and outer front hub wheel bearings
>Complete replacement of brake system: new front calipers, new master cylinder, new vacuum booster, new brake line hoses, new front brake pads, new rear brake cylinders, new rear brake shoes, new rear brake self adjusting mechanisms. Original proportioning/metering/pressure differential valve assembly refurbished by professional restoration shop. Installed Silicone DOT 5 brake fluid.
>New fan, power steering, alternator belts
>New reman power steering pump, new power steering pressure hose and in-line filter.
>Ignition system: New autolite spark plugs, new distributor cap, new rotor, new spark plug wires.
>Replaced tires 1240 miles ago, per DOT date code 4 years old.
 Price: $12,000, or near offer.
 Note: I will remove the ad when the truck sells, please don’t ask "Is this available?" If you are interested, contact me for a time to see it. Local pick up only.
